How to install Ramifier with TST already hooked?
Old Dec 19, 2005 | 06:15 PM
whatdieseltoget's Avatar
Is this an easy install. Im getting the Ramifier delivered soon. I already have the TST hooked up. Can someone walk me through the install or point me in the right direction. Thanks.
Old Dec 19, 2005 | 07:04 PM
JCLeary's Avatar
Install the Ramifier MAP plug into the TST MAP plug, and the TST MAP into the sensor. You don't want the TST to see the boost readings from the Ramifier.
As for fueling, do you have a fuel pressure gauge, or a pusher pump yet?
I can pull my f/p down to zero with the TST on 4x4. It goes to zero even faster with the BDDL stacked. A pressure box will pull it down even faster.
I think your next mod should be a FASS or similar unit. Otherwise your truck may lose power at the high end.
Old Dec 20, 2005 | 01:19 PM
I dont have a fuel pressure gauge yet. Will be getting it beofre the Ramifier is installed though. I drive around with the TST set on 1 and rarely use the power. Im gonna run the ramifier low as well until I get an FASS. Thinkin i might get decent mileage out of this stack with the ability to turn it up a little to impress so me Ford and Chevies. Plus i will have bragging rights.
What kind of power can be seen with just these mods. Intake, exhaust, TST, Ramifier?
Old Dec 21, 2005 | 07:50 PM
fordper4mance's Avatar
I just dyno'd my truck with those exact mods as well as a clutch and pusher pump and mine made 400HP and 800 FT LBS. I thought it should have made more but i think the pressure relief valve is leaking off pressure in the rail. This was on 7x7 and about 60% ramifier, others say it could have made more power if i would have turned it down a little more
Sniper05
17
Mar 28, 2008 08:11 PM
W.F.O.
15
May 27, 2006 11:49 AM
dieselrammer
Jul 7, 2005 12:51 PM
Dave04600
May 25, 2004 07:52 PM
Copenhagenjunkie
Dec 27, 2002 05:45 PM
