How the heck are you fitting 35's?!?!
Old Feb 12, 2006 | 06:23 PM
ocsurf16's Avatar
How the heck are some guys fitting 35's with no lift???? Ive been searching for a long time for what size to get with no lift...My buddy had got 285's on stock rims which i belive is about a 33inch tire????..but sure doesnt look like he has a lot of room to fit anything biggger, and he has a spacer front lift!!!!!
285's=33's?
315=35's?
295=?
305=?
anybody with pictures????
Old Feb 12, 2006 | 06:32 PM
tristan21's Avatar
I also run the 285's and I measured mine before installing them and I came up with closer to 32". The tire shop told me they cannot tell much difference in the 285, 295, and 305.
As far as fitting the 35's I have seen that most people on here running them are running the stock wheel. I wasnt so sure that with the tires stuffed in the fenders while four wheeling that I wouldnt have some good rubbing. But it may be alright if your gonna stay on the street. I have heard that at full lock some guys still rub a little. If your tire guy is good he might be able to set you up with a backspacing that will work for you but you might end up with a litte bit of that "beaner" look.
Old Feb 12, 2006 | 07:04 PM
bama's Avatar
i have 35 mastercrafts..stock,they are tight.i would have a little rub on the valence when twisting thru offsets.i put spacers on the front to level it,and havent had them rub since......this was on h-2 wheels,i never ran them on stock wheels..........bama
Old Feb 12, 2006 | 07:06 PM
HdPower's Avatar
I have 315's no lift H-2 Wheels no rubbing anywhere.
Old Feb 12, 2006 | 07:17 PM
PimpRohr's Avatar
You have any pictures of your truck on the H2 wheels?
Old Feb 12, 2006 | 08:11 PM
bama's Avatar
look in the member galleries at.....danram11 s gallery.........
Old Feb 12, 2006 | 09:57 PM
HdPower's Avatar
Yup check my gallery.
Old Feb 13, 2006 | 06:16 AM
blown32's Avatar
315s on H2 wheels, check my gallery for photos as well.
Old Feb 13, 2006 | 07:08 AM
mjsandt's Avatar
I have BFG AT 315's on stock wheels, and it only rubs slightly at full lock. Other than that, no problems with mine.
MJSandt
Old Feb 13, 2006 | 08:28 AM
milehigh.o.'s Avatar
Check my photos. I am running H2 wheels and Nitto 295's and no lift. No problems here.
Old Feb 13, 2006 | 09:04 AM
StrokeThis2500's Avatar
how yall sittin so high stock mine sits low
Old Feb 13, 2006 | 09:45 AM
nriver's Avatar
me too, BFG MT 35's on stock wheels. Rubbing on the control arms only at full lock and some flex.
Old Feb 13, 2006 | 10:17 AM
Patriot2500's Avatar
My 35's were rubbing on the control arms at full lock. Added some 2' Daystars and Rancho shocks and problem solved.
Old Feb 13, 2006 | 01:10 PM
Goggleyed's Avatar
35" Nitto's on KORE Weld's. They rub on the control arms if the steering wheel is cranked over more than 1.25 rev's in either direction.
Old Feb 13, 2006 | 04:33 PM
PimpRohr's Avatar
I just put on Pro Comp XTerrains 35x12.50x17's today on a stock truck with stock wheels. There is no rubbing but I am waiting for my RevTek leveling kit to come in to finish off the stance.
