How to find boost leaks?
Old Oct 27, 2008 | 09:21 AM
BossHogg's Avatar
I've recently installed a new set of boost tubes on all the inlets and outlets under the hood including turbo etc. I've also had the manifold gaskets and turbo gaskets replaced, and this past week I noticed that it sounds like I've got a really small boost leak somewhere. What's the best way to track down a boost leak?
The leak only appears or should I say I can only hear it only on SOME WOT runs, doesnt happen every time? Its kinda weird.
Old Oct 27, 2008 | 12:24 PM
5.9Excursion's Avatar
Go to your local plumbing store and buy a 4" to 4" rubber coupler, a 4" pvc fitting that slips inside it with internal threads on the other side and a 4" threaded cap. Drill the cap and thread it to accept an air hose connection. Dial down the regulator on your air compressor and pressurize your air intake (remove intake setup and place this on your turbo inlet). Keep in mind if you don't secure it tight enough, the assembly will blow of the turbo...
good luck...
Old Oct 27, 2008 | 01:12 PM
BossHogg's Avatar
Sounds easy enough. One question though, when I do this how will I know when the system is pressureized enough? I guess I'll start hearing where my leak is first? Do I need to tighten down the 4" inlet to the turbo first with a hose clamp or something?
Old Oct 27, 2008 | 01:27 PM
Yes, tighten the rubber coupler down with clamps. Usually you can find any leaks with much less than your normal boost pressure (soapy water in a spray bottle works well too, look for bubbles).
Old Oct 27, 2008 | 01:51 PM
WUnderwood's Avatar
do a search, this has been posted a few times before
Old Oct 27, 2008 | 03:17 PM
CrashCade's Avatar
https://www.dieseltruckresource.com/...st+leak+tester
Old Oct 27, 2008 | 04:39 PM
cincydiesel's Avatar
Second the soapy water. Worked great for finding mine
Old Oct 28, 2008 | 04:01 PM
XXLTEXAN's Avatar
while you got a bucket of soapy water you can give yourself and your truck a bath...erbody wins
abchoppers
Jan 26, 2011 05:38 AM
CTD2001
13
Sep 6, 2005 05:11 AM
thumbs
Jul 20, 2004 10:49 AM
Crimedog
May 25, 2004 09:18 AM
thumbs
Oct 22, 2003 01:02 AM
