How big is the compressor wheel on stock turbo?
Old Feb 6, 2008 | 09:47 PM
Big Blue24's Avatar
Are all of the 04.5-06 turbos the same? I have on that says Holset 2 on the compressor housing and it measures just under 2 3/8" so it is 60mm.
I've heard some claim that newer 3rd gen turbos are 62mm, does anyone have a 3rd gen turbo handy and want to measure it?
Also, the wastegate is precisely 7/8" with a 1 1/4" puck so total wastegate volume is 22.225 mm but if you opened up the passage to 1", you would gain 25% more flow and still be able to retain the stock puck.
Old Feb 6, 2008 | 10:08 PM
Spooler's Avatar
Perty sure it's 57mm.....
Old Feb 6, 2008 | 10:41 PM
Big Blue24's Avatar
It might be 57mm on the 03 early 04 trucks with the HY9, but I measured my HE 351 and it is definitely between 59 and 60 mm.
In fact, I think the 03-04 compressors are more like 54-56 mm, and according to HTT, flow a smidge more air than a HY35 found on 01-02 automatics.
Old Feb 6, 2008 | 10:47 PM
PourinDiesel's Avatar
Its more a claim of inducer size. The 62mm turbo's usually are advertised with a 62mm inducer and when you measure the bore on the compressor housing it is 62mm typically...same goes with a stock turbo for a 04.5-07 5.9L.
The 03-04 inducer is about 58mm...
To answer your first question: Yes, they are all the same for that model year range.
Old Feb 6, 2008 | 11:15 PM
Big Blue24's Avatar
Thanks Pourin! That was the info I wanted to hear!
Old Feb 7, 2008 | 07:21 PM
sallyman1's Avatar
what do u measure for the size? the size of the fins?
Old Feb 7, 2008 | 08:41 PM
Big Blue24's Avatar
Fins or the housing bore right next to the fins. Obviously fins will be 1/2 mm smaller or so.
Old Feb 7, 2008 | 08:47 PM
mikmaze's Avatar
only half a mm smaller till they spin a hundred thousand rpm while hot, then they get a lil bigger !
Old Feb 7, 2008 | 10:03 PM
sallyman1's Avatar
so stock is only 5.4cm opening? where fins are? mine is like 4 inch opening almost
Old Feb 8, 2008 | 01:58 AM
Big Blue24's Avatar
There is a 4" opening on all holset turbos that came on cummins from 89 to 08'.
There is another bore inside the 4" inlet bore that is just shy of 2 3/8" or 60mm.
WhoCares79
Jun 3, 2008 11:45 AM
Camarogenius
Jun 25, 2007 08:55 PM
JKM
Mar 8, 2006 03:23 AM
PourinDiesel
Apr 1, 2005 04:18 PM
