how to...
Did you spin the allen screw in all the way? The Silver Bullet best boost is around 50-55psi anything more is out of it's efficancy range. There are guys making over 700hp with only 50psi of boost.
You should be able 2 see 45-50 no prob.The screw is on the compressor on a little brass elbow. it is a black screw turn it in to get more boost. Mine came set at like 48-50ish but i've seen spikes of 54 or so
Here, this is what you want. You should be fine up to 50 psi.
http://cgi.ebay.com/ebaymotors/DODGE-CUMMINS-TURBO-TURBOCHARGER-ADJUST-BOOST-ELBOW_W0QQcmdZViewItemQQcategoryZ33742QQihZ002QQit emZ120208268554QQrdZ1QQsspagenameZWDVW
I just took a look at the boost elbow...but everywhere i look its says not for an 04.5. Does this mean stock turbo? Will it work with the silver bullet or am i SOL for this elbow cuz im 04.5?
