HMR Street Drag DD chirps
Old Mar 1, 2009 | 11:09 PM
# 1 FAN's Avatar
Is it normal for this clutch to chirp when you down shift. If you don't let the clutch out right it will chirp to. It is not sliping gust making werird sound.
Old Mar 2, 2009 | 08:37 AM
XLR8R's Avatar
Chirping rubber?
Old Mar 2, 2009 | 10:32 AM
# 1 FAN's Avatar
No the clutch makes the sound.
Old Mar 2, 2009 | 10:34 AM
Megadeth's Avatar
it only happens when you downshift? never from a stop?
Old Mar 2, 2009 | 11:13 AM
# 1 FAN's Avatar
Yes,if i let the clutch out wrong it will make the same sound
Old Mar 2, 2009 | 11:24 AM
banshee's Avatar
Mine has always been quiet on engagement. The street puller with the sintered iron pucks will chirp, however. Not sure what the issue is.
Old Mar 2, 2009 | 01:06 PM
matego's Avatar
madhat's monkey boy...
Its only going to get worse. It started 6th to 5th then progressed from 5th to 4th. Now it sounds like I have a squealing pig in my bellhousing when I pull out in 2nd gear.
I know what caused mine. My flywheel is so blue you can see it through the little hole in the bottom of the bell. Too many 3rd gear launches at the track with 35's I was too lazy over the summer to take my smaller track tires and I have now paid the price
If it annoys you that much, when downshifting try blurping the throttle to rpm match the shift. It does not squeal then.
Old Mar 2, 2009 | 01:57 PM
# 1 FAN's Avatar
Is it something to worry about. The truck is now to me it has 2,500 on the clutch. I have another ?,the clutch does not engage until the last 2-3 inches on let out of the pedal is this normal?
Old Mar 2, 2009 | 02:44 PM
53 willys's Avatar
hey guys this is my old truck he's talking about...
I never even did a 3rd gear launch with this clutch or the stock clutch.
I never had a DD before this one so I assumed it was normal from what I have heard from other people?
it has chipped since install...it did not do it all the time on me..only when I shifted or launched weird.
that clutch should e in great shape I hardly even drove on it.
it for sure takes some getting used to..
Old Mar 2, 2009 | 02:50 PM
Brokenarrow's Avatar
It's fine Haisley's will do that...
Old Mar 2, 2009 | 05:36 PM
53 willys's Avatar
Don't forget this is a SOLID hub clutch....it's all business!! :-)
Old Mar 2, 2009 | 07:19 PM
# 1 FAN's Avatar
Mark You get your race project?
Old Mar 2, 2009 | 07:41 PM
Nsomniac05's Avatar
i got a SBC DD and it does that too. and if you let it coast and your speed gets too low for your gear it kinda does a mixture of a little chirp and a little rattle. I thought it was a bad thing after i got it broke in, but i realized after a while that the clutch still holds fine, you just gotta not put it in those situations if you dont wanna hear the noise.
lbdodge24v
Apr 22, 2011 09:22 PM
Dwitt0187
May 7, 2008 01:55 PM
gtaj4
Aug 23, 2007 08:16 PM
Mike D
Jan 20, 2005 10:14 PM
SmokinDodge12V
Jul 12, 2004 07:54 PM
