Hit the scale at 11,502
Old Jul 3, 2007 | 02:57 PM
rynemurch's Avatar
I used my bed for the first time and put 4000 pounds of rock in there and she still drove good! I love this truck the over head reading read 16.5 mpg all the way home!!!!!!!!!!!!!!
Old Jul 4, 2007 | 05:41 AM
TAS05CTD610's Avatar
That's a Lot of rock for the truck. Not that it can't handle it, but you are over loaded. The 2500's are only rated for 9,000lbs gross, so 1 ton of stone is about all you "should" carry. 4,000lbs is a lot of weight. (not to mention any fines you could get)
2nd, if you even think about calculating your millage off your overhead, put a piece of tape over it, it's about as accurate as a math teacher in the dark. Those things are normally 2-3mpg off, so hand calculations are the only way to check.
Other than that, these things do great pulling, towing, ect.
Old Jul 4, 2007 | 08:26 AM
2003Ram's Avatar
I was at 11,700 in my '03 shortbed, same load, dirt and rock. When I hit the scale I just got a look of amazement from the girl in the booth.
Old Jul 4, 2007 | 11:53 AM
benito's Avatar
I'm regularly at 17k when leaving the pit...
Old Jul 4, 2007 | 12:53 PM
steelblitzkrieg's Avatar
DTR Detective
Curious as to how much sag you had.
Old Jul 4, 2007 | 03:47 PM
OR Mega Cab's Avatar
And your front tires are still on the ground?
Old Jul 5, 2007 | 01:39 PM
tbarbee1's Avatar
My truck weighs 8820 empty.
Old Jul 5, 2007 | 08:17 PM
rynemurch's Avatar
You could tellI had a load she sag but not as much as I thought it would!
Old Jul 5, 2007 | 10:40 PM
2003Ram's Avatar
4500# in my stock 2500 and still drove pretty good considering. It was a little squooshy in the turns.
Trooperthorn
Jun 9, 2014 10:53 PM
jrs_dodge_diesel
Jul 22, 2011 06:12 PM
DodgeCTD
22
Jun 21, 2008 09:39 AM
Billm2004
38
May 15, 2008 06:24 PM
damon_achey
Mar 24, 2003 05:30 PM
