Higher 6th Gear??
Old Aug 20, 2008 | 11:16 AM
  #31
mcolectd's Avatar
Ya they do seem high, but I dono what would be wrong. My speed seems right. I recalibrated it with the smarty, and the other day I passed one of those "your speed" radar signs on the side of the road and it matched my speedometer pretty close. So I dono...
Old Aug 20, 2008 | 11:27 AM
  #32
elirandolph's Avatar
Originally Posted by Hintz
Only the newer 6.7's have the taller G56
this is not true. there are some 5.9's that have them. roperteacher has one. maybe he will chime in.
Old Aug 20, 2008 | 01:40 PM
  #33
06megacab5.9's Avatar
the cut off date on the newer trans was 5/06 any trans built after that date has the higher ratio 6th gear. i know of some trucks built late 06 that stll have the old g56 . so dont know when dodge actually started putting the nw ones in .im thinking early 07 . when you order parts for the trans the cut off date on the old one is 05/06
Old Aug 20, 2008 | 02:21 PM
  #34
jmccart's Avatar
What is the ratio of the new G56? The old one is .79 or .78, right?
Old Aug 20, 2008 | 02:38 PM
  #35
AH64ID's Avatar
The new one is .74, the old one is .79. The NV5600 was .73...
I have an 05 NV5600 and my dad has a 06 G56, both rigs have 3.73's... My dad can pull just about any interstate hill with 7-10K behind him in 6th gear, I cannot... Thats the difference that ~200 rpms makes...
A early G56 with 3.73's turns about what a NV5600 with 4.10's turns, in OD.. Hence no 4.10's with a G56.
Personally I would like to have a .80 and a .70 OD, a towing and a empty OD... I may add a US Gear OD unit down the road, which would give me a .80, .73, and .58 OD's....
Old Aug 21, 2008 | 12:57 AM
  #36
PRO-NRA's Avatar
Look at your G56 and llok for P52104714AE. If it is an "AE" then it is the taller OD.
Old Aug 21, 2008 | 08:26 AM
  #37
mcolectd's Avatar
Ok will do. Not that I can afford to switch it if its not right now anyway
Old Aug 21, 2008 | 12:42 PM
  #38
Hintz's Avatar
Originally Posted by cquestad
Noooooooo...same gears.
yesssssss different gears
Old Aug 21, 2008 | 12:43 PM
  #39
cquestad's Avatar
I ment the rear end....no OEM 3.42????
Old Aug 21, 2008 | 12:44 PM
  #40
Hintz's Avatar
Very cool, he must of had an extremely late built 5.9, I which I had that tranny
Old Aug 21, 2008 | 12:45 PM
  #41
Hintz's Avatar
Yep, 3.42 OEM manuals only though
Old Aug 21, 2008 | 01:55 PM
  #42
AH64ID's Avatar
I really do not think that it makes a huge difference. My dad and I get about the same mileage, give or take... More often I wished I had a lower OD than a taller one.
Old Aug 21, 2008 | 02:09 PM
  #43
mcolectd's Avatar
Ya I read a couple guys sigs that have the 08s with g56, and they all say 3:42 gears
Old Aug 21, 2008 | 04:02 PM
  #44
AH64ID's Avatar
Which is a really tall gear set with the new G56. Thats 1950 at 70, vs 2260 at 70 with 3.73's and the early .79...
Old Sep 18, 2008 | 09:10 AM
  #45
haulin87's Avatar
1950 @70 would be sweet!
1950@62 blows!!
