High Flow Exhaust with Muffler
Old Jun 12, 2006 | 08:05 PM
Duallydog's Avatar
Parts for Operation Silent Thunder are ordered. If you do not know what I am talking about search it.
Old Jun 12, 2006 | 10:24 PM
WUnderwood's Avatar
what part(s) would that be?
Old Jun 13, 2006 | 06:26 PM
Duallydog's Avatar
That would be an exhaust cut out (pipe part, Y-pipe) and the electric exhaust cut out (the expensive part).
Old Jun 13, 2006 | 08:36 PM
gsbrockman's Avatar
I often wondered if it would be possible to have an aftermarket system with a muffler as far forward as possible, use the exhaust cut-out, then tie the bypass straight back into the existing tailpipe, actually bypassing the muffler........with the flip of a switch, you could have muffler or straight-pipe all whilst utilizing the same exhaust pipe & tip.
Greg
Old Jun 14, 2006 | 01:01 AM
sled4fun's Avatar
Greg
I don't see why it would'nt work if there was enough room for the bypass pipe.
Old Jun 14, 2006 | 06:50 PM
Duallydog's Avatar
I'll just have duals one behind the rear tires and one infront. I have'nt seen a Cummins with the exhaust infront of the tires, but one of the guys on my rodeo team had a 99 F-250(converted to 450) with the exhaust infront, it sounded like a train, I bet the cummins would sound better. Mine won't sound as good as someone with a 4" exhaust all the way from the turbo through the tip; mine will be 3.5" through the dump and probably 3" to the 4" to 5" tip (My exhaust guy can only bend 3").
I think I'll change the name to Operation Sound Sleeper. It'll sound stock when I want it to. This will also play into Operation Market Garden (no not Hitlers plans) My marketing stategy for my company.
Old Jul 9, 2006 | 10:46 PM
Duallydog's Avatar
Well all of the parts are here, now I just have to get my welder guys schedule and mine together on the same page. Usually I'm the one gone to a roping, I guess it was his turn.
Old Jul 11, 2006 | 10:04 PM
Duallydog's Avatar
Now I am trying to figure out if it would be better to put the switch on the shifter or not. How hard is it to run a wire through the boot?
Old Jul 12, 2006 | 08:37 AM
displacedtexan's Avatar
I don't think it would be that hard to run a wire through the shifter boot...
But I had a 99 with exhaust in front of the wheel. LOUD. Especiallt since my muffler and resonator wer elsewhere. But sounded awesome.
Old Jul 12, 2006 | 11:44 AM
tomgreentwin's Avatar
My current setup on my '94 is pointing out before the rear axle. It's stock downpipe into a 4" straight pipe and then a 6" tip on the end. Looks kinda large there, so probably put it out the back with a tailpipe eventually.
It's loud, but I wouldn't mind louder with a 4" downpipe and 5" straightpipe.
With a few mods about to take place, I am thinking the soot factor will be an issue soon.
Old Jul 17, 2006 | 09:25 PM
Duallydog's Avatar
whooo whooo. I just dropped my truck off at my exhaust guy's place. I should have it tommorow. He has some incentive to get it done quickly since he is going to be taking it to work instead of his truck. When I drive it I'll give a breakdown of it.
Old Jul 18, 2006 | 07:48 PM
Duallydog's Avatar
Well it's part done, got the muffler on. The cut out should be done next week. Ther truck sure is quiet now, and it drives good. I can run through the rpm without hesitation. Before when I hit 2300 it was loud enough to make me back off. The boost seems to be higher without the muffler.
capt.Ron
Feb 15, 2008 09:55 AM
ralphyboy
Jan 17, 2008 08:35 PM
toupee
May 4, 2007 11:49 PM
DRKelly
Dec 1, 2006 11:02 AM
8mpg
May 22, 2006 01:35 PM
