Hi Hot Hi Hot its Smarty Beta 4.4 s04 I got
Old Jul 13, 2007 | 12:24 PM
  #91
LooseBoltsRob's Avatar
Originally Posted by dodgezilla04
stacking pressure with the beta 4.3+4 is probably not a good idea, since the later beta's add a small amount of pressure. but bob would know best.
Yes, I'm stacking my MP8 but turned down. The rumor is that 4.4 adds "little" presure, so I don't see any issues with running my MP8 at 30-40%.
Old Jul 13, 2007 | 12:29 PM
  #92
tcr's Avatar
tcr
I'm toying w/ the idea of running the lower settings on 4.4 at 1-3-5 w/ 60hp Quad setting, but I also know one of you guys blew a freeze plug w/ this setup right? Dodgezilla maybe?
Old Jul 13, 2007 | 12:31 PM
  #93
tcr's Avatar
tcr
Originally Posted by MikeyB
You're kidding me!!??
MikeyB
Nope and nope
Old Jul 13, 2007 | 12:36 PM
  #94
dodgezilla04's Avatar
yep, that's me. i blew my plug with 4.2 and quad on 140 ooops
but it was probably from not completely warmed up.
Old Jul 13, 2007 | 12:54 PM
  #95
O.T's Avatar
O.T
so I should not tow with the 4.4 or 4.3 what software do ya recommend for towing 12k over the mountains??
Thanks
onetun
Old Jul 13, 2007 | 01:27 PM
  #96
rob, i used the aftermarket turbo/stop sticks wild on #2. towed 10k over the divide to montana.
Old Jul 13, 2007 | 01:36 PM
  #97
abc4yew's Avatar
Bob, I'll have to erase towing that 25k load from my memory along with the other 4k of miles I've put on towing in the last month. You need to have alot of common sense to run the Beta's while towing....Having water helps....I don't use enough of the skinny pedal to go over 22psi when towing...and I tow more in 3rd than I ever have to keep the revs up. So far all has been very very good. I accidently towed on Beta 4.4 sw7 once.....that was hard to control as the fuel would pour on in a second. Empty is a blast though. Keryr
Old Jul 13, 2007 | 02:00 PM
  #98
jgiachino's Avatar
Originally Posted by Bob Wagner
PLEASE DO NOT RUN THE BETA SOFTWARES ON STOCK TRUCK
- Can we get a little detail on this one too??? Is the concern EGT's / Trans Life / Fuel Pressure ??? Please shed light on "Stock Truck"...
Old Jul 13, 2007 | 10:57 PM
  #99
sid325's Avatar
That's weird. I've noticed more low-end power with 4.4, but nothing drastic. I'm running level 5 and would compare it to approx. moderate on level 7. Oh, and Bob my tranny loves the new program. Night and day difference, 100% better. Smokes much less, smoother idle, smoother acceleration, quieter, and shifts great. Whatever was done for the shifting, please don’t change it.
Jacob
Posted on TDR also.
Old Jul 14, 2007 | 10:33 AM
  #100
JThiessen's Avatar
If you read what Bob said, " finally got a dyno......numbers were higher than anticipated", he was referring to the hp/torqure numbers. We've all noted that EGT's have held in check, so that obviously wasnt an issue, and did not need a dyno to test.
And I believe he was speaking about only 4.4, but you should get clarification.
I for one towed with 4.4 on level one and it was readily apparent that hp levels were not within the parameters. Hopefully, the slipping didnt do any permanent damage to the tranny.
Old Jul 14, 2007 | 01:22 PM
  #101
KKB's Avatar
KKB
I have towed with beta 4.4 on SW#5 and my Goerend tranny has been great, I am glad it is not stock. Beta 4.4 on SW#5 feels a bit stronger that SW#7 that originally came with the smarty. Since my tranny can handle the power and EGT's are good is there any other reason not to tow with the beta? When I tow it is only an 18 foot ski boat that I would guess is 3500 #s at best so any reason not to use the beta?
Old Jul 14, 2007 | 01:39 PM
  #102
gitchesum's Avatar
I picked up 172HP with the Beta 4.3 program on Level #1.
Most stock trucks won't like that kind of power through the tranny.
Big Smoky
Jun 8, 2008 08:13 AM
tt433
May 13, 2008 08:07 PM
Coal Train
May 12, 2008 09:11 AM
dodgecowboy04.5
May 9, 2008 05:44 PM
jrussell
37
May 31, 2007 08:04 PM
