Hey Gypsyman! Grill Guard question
Old Nov 16, 2004 | 08:30 PM
030303's Avatar
Where did you buy that Waag grill guard? I don't think there are any dealers here in St. Louis so I'm buying online. Thanks, John
Old Nov 16, 2004 | 08:58 PM
Gypsyman's Avatar
I picked mine up at Custom Truck in Spokane Wa. Over hear it seems like most Westin dealers also have access to WAAG. I'm on the road right now but if you need more help locating one let me know.
martin1133@msn.com
Richard
Old Nov 17, 2004 | 08:22 AM
dodgedude361's Avatar
I`m admiring it as well, is that the "center" guard? Do you know the part number on that one? I found an online outlet that has themn.
Also, i LOVE the stacks, Did you do the install yourself?
thx
Old Nov 17, 2004 | 10:51 AM
Gypsyman's Avatar
It's just the center portion of the full gaurd. As far as the stacks go, I did the fab and install of the stacks and the modified tool box myself. Man, this is one fun truck!
Richard
Old Nov 17, 2004 | 12:16 PM
cquestad's Avatar
Hey Gypsyman, how do you like your VA stack with the TST? Any dyno numbers?
Old Nov 17, 2004 | 12:57 PM
Gypsyman's Avatar
I can't say enough good things about this stack! Over 240 fueling combo's and I can kill the pressure with a flick of the switch when I don't need it. Pressure on 100% makes 3x3 about even with 5x5 without pressure. I'm still on the road but now that I'm confident with the stack I'll try to dyno it when I get home. I finally got to tow with the TST, C3.1, and the B1-04 and what a great combination! Grossing just a hair under 18,000 with my barn door of a gooseneck I set the TST on 3x3 at 75 mph. EGT's up any grade never exceeded 1076* at about 30 lbs and the truck never dropped below 72 mph! No down shifts and zero problems. I didn't even need the C3.1 to tow so I just use it to play or for running empty and improving mileage.
Richard
Old Nov 17, 2004 | 01:23 PM
signature600's Avatar
Dern Computers
Glad you like them, though.
Chris
just Kiddin', the only "real" thing bad about computers is they're making stuff for my truck become obsolete
Those new truck's get all the goodies, like EDM injectors
Old Nov 17, 2004 | 01:42 PM
cquestad's Avatar
Does it fatten up the bottom end on the TST? I really liked the VA CP3.2 in terms of low end, but it fell kind of flat near the top. The TST hits really hard up high..but not as much down low. Trying to decide if a little pressure added to the TST is the ticket.
Old Nov 17, 2004 | 01:54 PM
Gypsyman's Avatar
I really prefer the driveability and the incab controls of the VA over the EZ. It seems to bring the boost up about 400 rpm sooner which lets the TST fuel sooner also. Still no monster bottom end as I've heard comes with the original TST but it seems to roll in a lot harder with pressure. Remember that the B1-04 spools a little slower than the stocker which I believe also contributes to the softer bottom end. I'm looking for another TST (cheap) so that I can experiment with different programs from Mark. I must say though that my current combo seems very linear and pretty easy on the turbo down low but just keeps building all the way to red line. For an 8500 lb truck this critter flat moves out and really catches people by suprise.
Richard
Old Nov 17, 2004 | 02:02 PM
cquestad's Avatar
That is the problem with the TST...no boost...no fuel. Quicker you will make boost...more TST will fuel. Need something to fuel quickley regaurdless of boost to over come the side effect of a larger turbo. Almost like twins or a VGT turbo...need multiple stage fueling!
Does the Edge EZ (or other simple pressure box) only fuel on boost or just pedal input?
Doug, where are you man?
Old Nov 17, 2004 | 02:12 PM
Gypsyman's Avatar
The EZ only fuels on boost from what they've told me and the fact that the only input is from boost. The VA is three dimensional. Boost, throttle position, and RPM. Just what I've been told by the manufacturers.
Old Nov 18, 2004 | 05:30 PM
030303's Avatar
For the record I e-mailed WAAG, and they said if you order the "center" section only it is the same part that comes with the full 3-piece brush guard. Mine's on order. Thanks Gypsyman!
Old Nov 18, 2004 | 05:58 PM
Gypsyman's Avatar
Glad you got it worked out!
Richard
prairie pirate
Introductions / New People
Jan 18, 2009 10:26 AM
jaredbs
Feb 6, 2006 08:35 PM
donnee
Nov 12, 2005 12:57 PM
