HELP walbro pump install.
Old Nov 1, 2008 | 11:10 AM
vj_M's Avatar
Ive been playing with this pump for 2 days now i installed it in line with my stocker in the tank and winding up with 50+ psi (way too much!). what my question is that can i disconnect the stock pump and let the walbro suck threw the stock pump and use the wiring from the stock pump to feed the walbro? (Understand?)
Old Nov 1, 2008 | 12:02 PM
tcr's Avatar
tcr
Are you using a regulator? And yes you can suck through the stock pump.
Old Nov 1, 2008 | 12:05 PM
JJPage's Avatar
You have to have a return line back to the tank.
Go to Richards website www.glacierdieselpower.com
He has instructions for installation.
Old Nov 1, 2008 | 12:08 PM
tcr's Avatar
tcr
By the way, 50 psi is not too much for a stock CP3, it is too much for your stock fuel filter set up though. You must run a regulator w/ a return line to your tank(fill tube).
Old Nov 1, 2008 | 12:09 PM
Pooter's Avatar
You need to regulate that walbro somehow, either a return manifold style or a dead end regulator.
As for sucking thru the stock pump, im not sure if it can suck enough thru the stock pump, I thought that the pump(on the intank pump setups) kept the bowl in the pickup assembly full of fuel, and basically without the pump sucking the fuel into the bowl, it would more or less starve for fuel sometimes? Whereas a 03-04 pickup doesnt have that problem.(Too bad the only alternative for 04.5 guys is either a pickup like glacier has, or to use a liberty canister and modify it)
Heres a few more pics/info from the install we did on my buddies truck...
http://wiki.dieseltruckresource.com/...l_Filter_Setup
Old Nov 1, 2008 | 12:16 PM
vj_M's Avatar
thanks guys for the fast replys but i had it with that thing!!! i just tore it off and iam going to order an air dog 150 system! anyone still have them things for 499?
Old Nov 1, 2008 | 02:09 PM
RonP's Avatar
The system is as easy as any to install. do you have the complete glacier system?
I wouldn't give up that easy.
Old Nov 1, 2008 | 10:22 PM
vj_M's Avatar
no i don't have the complete system, i ordered the pump and thats all i got. i was just gonna hook it up in line and run both, off the stock wiring and a 1/4 turn valve for a regulator but thought that it was too much back pressure?
Old Nov 3, 2008 | 09:23 AM
HappyGA's Avatar
You should have ordered the entire system. My DTR group had a meet and wrench and had mine installed in about an hour.
Old Nov 3, 2008 | 09:45 AM
vj_M's Avatar
thats what i thought i was getting when i ordered it, but when it came all it was was the pump in the box. i just need to pick up a check valve and it will be donei have a 1/4turn valve on there for now just cracked a bit closed so it reads 25psi on my gauge at idle but when i turn up the chip on level 5 i can drop it down to 2psi.
Old Nov 3, 2008 | 02:12 PM
vj_M's Avatar
well guys i was at it again today, i picked up one of them sweageloc check valves and set the idle at 20psi returning into the return line, i run threw 2 fleet guard filters and the stock canister with nothing in in. how ever...... when i have the chip on level 5 and i mash the peddle to the floor i can get down to 0psi again. what gives?? shouldn't that pump hold at least 10psi when wot?
Old Nov 3, 2008 | 02:31 PM
jlibert's Avatar
I set mine to 40 psi, and it doesn't drop past 20psi with a big cp3.
Old Nov 3, 2008 | 03:04 PM
vj_M's Avatar
i wonder if i bumped it up to 30psi at idle will that hurt anything?? ive heard of guys blowin the tops off the factory fuel canister tho........? :/
Old Nov 3, 2008 | 04:30 PM
yelloz28's Avatar
That walbro pump isn't meant to suck through the stock pump. It will cause cavitation issues
Old Nov 3, 2008 | 07:06 PM
vj_M's Avatar
its not sucking threw the stock one the stock one pumps up to it they are running together on the same line.
Buster2313
Dec 8, 2007 07:31 AM
Jordan5687
Sep 28, 2007 03:17 PM
bryanburns
Jun 18, 2007 12:20 PM
Jordan5687
Mar 1, 2007 12:06 AM
B.Law
57
Jun 1, 2006 10:46 AM
