Help w/home made torque tube
I went to install the rubber 90 on the turbo & the back of the 90 is hitting the oil filter! Did you guys cut the 90 or are you letting it ride on the oil filter? The most I can cut off is about 3/4".
Yep! Just cut as much as you can off the elbow you are going to install on the turbo. I took 3/4 in off mine. Just need to clear the oil filter by a hair, so that you can change the oil filter. I like my (built it myself torque tube) javahjoeo from Kokomo.
Idaho Guy
Nov 18, 2011 04:18 PM
Arkapigdiesel
Jan 13, 2007 10:47 PM
