HELP!! twins problem
Old Feb 14, 2009 | 03:02 PM
DodgeCTD's Avatar
Hey fellas just got the twins on and I cannot keep the intercooler pipe from blowing off..I am gonna try to double clamp everything to see if it holds. Here is my question, why in the world is there oil shooting out of the compressor outlet on the top turbo? I blew the intercooler boot and still had to drive a good ways, I open the hood and there is oil all over the place coming out the outlet of the top turbo??
Old Feb 14, 2009 | 03:09 PM
lmills's Avatar
that does not sound good. There should not be any oil in the turbo piping. If any oil got on the boot it will keep blowing off
Old Feb 14, 2009 | 04:44 PM
DodgeCTD's Avatar
what could be causing oil to go into the compressor housing???
Old Feb 14, 2009 | 04:47 PM
bluechrome's Avatar
The center section is the only place oil should which is complelty sealed. Something doesn't sound right
Old Feb 14, 2009 | 04:59 PM
DodgeCTD's Avatar
could it be that when I rotated the compressor housing a seal or something got misplaced? I hope I can fix this without having to take the top turbo off thats alot of work
Old Feb 14, 2009 | 05:43 PM
Billy Ram's Avatar
Check your drain. It may have a blockage.
Billy
Old Feb 14, 2009 | 06:26 PM
DodgeCTD's Avatar
I have a metal one that came off a semi...it has a slight smash in it. I just cant imagine it shooting oil out like that cause of that?
Old Feb 14, 2009 | 06:33 PM
bluechrome's Avatar
You need to pull the coldpiping off and pull the compressor cover and c if there is oil Coming from Behind the wheel
Old Feb 14, 2009 | 06:46 PM
lmills's Avatar
you don't have any rubber hose joining any parts if the drain together? It only takes a small restriction for the oil to blow past the seals. Or you have a turbo that is going to need rebuilt
Old Feb 14, 2009 | 06:59 PM
DodgeCTD's Avatar
Yea I have some silicone hose thats joins it together with the nipples in the block...I never had a problem with it untill I put the twins on. And the turbo is only like 6-8 months old.
Old Feb 14, 2009 | 07:01 PM
DodgeCTD's Avatar
Pulling it first thing tomorrow morning. If there is oil coming from behind the wheel how am I suppose to fix that? I think this is where my problem is, I think oil is leaking into the compressor housing and getting blown into the piping
Old Feb 14, 2009 | 07:10 PM
lmills's Avatar
I would check that spot to make absolutely certain that it is not kinked at all. Silicone hose, when used in oil drains, can get soft and flex easy when hot. Especially if it is silicone hose not rated for oil. Check that before pulling the turbo.
If that is not the case, pull the cold pipe and see if there is oil in that. You need to determine which turbo the oil is coming from. If it is coming from the top turbo, you can leave the exhaust housing bolted to the manifold and hot pipe, and remove the center section to do the rebuild
Old Feb 14, 2009 | 07:11 PM
pullin hard's Avatar
what twin kit do you have?you have any pics of how you installed them? something is not right.
Old Feb 14, 2009 | 07:22 PM
DodgeCTD's Avatar
Got the cold pipe taken off and check it..no oil in it. Bottom turbo is good to go...Looks like the top is my problem
Old Feb 14, 2009 | 07:24 PM
DodgeCTD's Avatar
I ordered hot pipe,down pipe, and mounting bracket from source automotive. I fabbed the intercooler pipe and cold piping myself. I have not taken any pics yet of the piping. Truck ran great besides blowing the intercooler pipe off when i get into it.
