Help!! Question concerning rear leaf center pins......
Old Aug 19, 2008 | 03:54 PM
06CTDforAU's Avatar
I'm in need of the factory center pins that came on my truck. They are replaced when installing the Carli mini-packs (or full leafs) and somehow mine got lost during the installation. Would any center pin work fine? I was going to order some from the dealer but they can't seem to find the part number. My local dealer sort-of sucks at looking stuff up. Any help would be appreciated.
I know the factory pins are 1/2" so do yall think these would work?
http://store.topguncustomz.com/store...43&i=170111936
Old Aug 19, 2008 | 04:53 PM
Diesel Doc's Avatar
just buy some from a 4wd shop. they will be long so just cut off the excess
Old Aug 19, 2008 | 04:56 PM
06CTDforAU's Avatar
That's all I've gotta do? If so then I'm in business.
Old Aug 19, 2008 | 04:58 PM
Diesel Doc's Avatar
yea I have done a bunch of them just tighten them down then cut off the excess to about 1/2" from the nut.
Old Aug 19, 2008 | 11:05 PM
Raspy's Avatar
Just go to any good hardware store and get some Grade 8 fine threaded 1/2 inch bolts. The length will vary depending on whether you are running the lifting blocks and/or the overload pack.
You may have to grind the bolt head some, but hex bolts actually work better than regular center pin bolts because the axle hole is large and not round. Remember, there are two bolts per side and be sure to get Grade 8.
48 OFF
Aug 11, 2010 06:58 PM
jump
Jul 4, 2010 11:42 AM
GotPub
Jun 5, 2008 09:34 AM
Joe T
16
Jun 12, 2007 12:11 AM
jdeereboy
Nov 30, 2004 04:01 PM
