BD Tow twins wastegate adjustment
Old Aug 18, 2008 | 11:26 PM
DUKCALN's Avatar
I was told I should go ahead and shorten the wastegate all of the way. What would this accomplish? I have it set to 48 or 50psi. Any side affects from doing this or will it get me some more power.
Old Aug 18, 2008 | 11:31 PM
0lywrench's Avatar
im assuming it works the same on a single to twins,it does on mine,shorter rod most times more boost
Old Aug 18, 2008 | 11:38 PM
DUKCALN's Avatar
Will it affect egts?
Old Aug 19, 2008 | 01:54 AM
Snapoff's Avatar
If your gate opens too soon higher EGT's and some power loss will result.
Bd's turbos are set up tight and need to be run the same way.
Old Aug 19, 2008 | 04:24 PM
DUKCALN's Avatar
Tight meaning? By adjusting the rod all the way in, will the gate open sooner or later?
Old Aug 19, 2008 | 07:46 PM
AK RAM's Avatar
Shortening the rod will raise boost. Once you get above 60lbs, drive pressure starts to climb quickly. I wouldn't recommend shortening the rod all the way. Shorten it in small increments (two full turns at a time) until you reach 60 lbs and stop there.
Old Aug 19, 2008 | 11:17 PM
DUKCALN's Avatar
Thanks guys, I sure will stop at 60psi
dodgediesel
ABDTR #5
Oct 18, 2011 09:22 PM
dodgediesel
ABDTR #5
496
Oct 16, 2011 04:33 PM
dodgediesel
17
Apr 5, 2011 11:21 AM
Stock 02
28
Sep 24, 2006 11:09 AM
MoparRiggan
Oct 13, 2005 11:54 AM
