Help please.....
I'll be 43 soon.
just figured I would throw a name out there that does good work. I have worked in Surgery for 14 years and have seen plenty of hack jobs.... This guys is good at what he does and there are very vew orthopaedic surgeons that do foot/ankle work and even less that do total ankles. I just happen to know and work with one of the very few that does..... There are some podiatrists that do fusions also..... no thanks..... They should stick to the bunions.
36 years old here. been fighting it for nearly 10 years already. getting worse but too skeerd to have the procedure done and being down for 32 weeks (total for both sides) is not something I can afford nor would be able to handle.
Found the problem!!! I should of called DPS (Brett) in the beginning but I thought the problem was with the fuse/relay deal...
Brett told me to pull the wg plate to check the valves, see if anything looks out of the norm. BINGO!! One of the valve 'pins' broke and let the valves hang open, now I'll pull the turbo to check to see if that pinhead did any damage.
Oh, Bret (DPS) is sending me out a new housing on Mon.morning.....exellant customer service!!!
I know the feeling of going under the knife, plus taking a chance of the procedure malfuntion and coming out worse than you already are. Yeah, the chances are slim of that happening, but there is still a chance.....you do sign a release form before going in any operation....
I am supposed to wear the CPAP but the machine is old. I am headed to the VA when I get back from Idaho to get new set up. The kids and I have been here for the last 10 days on vacation.
MoparRiggan
Jan 17, 2006 12:43 PM
