help need quick answer to quad commander Question.
Old Jul 5, 2007 | 04:18 PM
Mopar72's Avatar
Question help need quick answer to quad commander Question.
Sorry for bothering everybody but i am in the process of installing the quad commander and i have a dumb question. Wear are you guys putting your quad commander ground at?? the instructions say to install on the bolt close to the firewall?? do they mean inside the cab or out side in the engine compartment?? so far it has been pretty easy install. the only bolt i see out side in the engine compartment. is a ground stud on the left uper inside fender behind the left battery. i was going to install the ground there but the ground wire is not long enough or i am doing something wrong?? any help would be very helpfull. thanks Mopar72
Old Jul 5, 2007 | 04:21 PM
cummins dsl's Avatar
it doesn't matter if it is grounded inside or outside the engine bay. it just needs to be grounded to some bare metal, don't use any of that cast aluminum it can cause issues with the commander readings.
Old Jul 5, 2007 | 04:29 PM
iweb's Avatar
I used a bolt on the inside close to where I ran the wires in through the firewall.
Old Jul 5, 2007 | 05:06 PM
Luvnacumns's Avatar
Me toooo!!!!
Old Jul 5, 2007 | 05:13 PM
ptgarcia's Avatar
I ground my Commander, Pacbrake, and light switches to a bolt behind the accelerator pedal, kind of low on the firewall. I think it's just above the carpet edge. If I remember right its a 13mm nut.
Old Jul 5, 2007 | 07:41 PM
Festus's Avatar
X2^^^^ Just the Commander though - the rest is let's say, different in activation.
Old Jul 6, 2007 | 12:50 AM
Mopar72's Avatar
hey guys thanks for the great info. i finaly decided to put the ground wire. on one of the E-Brake mounting bracket studs. thanks again for the help. so far the quad commander is working great. thanks Mopar72
mr. ed
Jan 7, 2011 10:08 PM
roxxx
Nov 28, 2008 04:47 PM
jmd025
Aug 8, 2008 06:07 PM
thxman
19
May 25, 2007 12:53 AM
Mopar_Mudder
19
May 16, 2003 07:34 PM
