Help with my tractor
Old Apr 26, 2010 | 09:52 AM
CLeger67's Avatar
Guys, I know this is not a "Tractor" forum but I figure there's gotta be some Diesel mechanics here. I gotta Mahindra 450 4 cyl diesel I just bought. It was running good and all of a sudden it sounds like its "missing" and acts like its running hot. The thermostat doesn't have numbers but it runs about 1/2 way to the hot line. It also smokes more than usual. I took out the injectors and had the tips changed out and replaced them but it runs the same. The exhaust manifold has 2 small holes that I guess are suppose to be there. They look bigger than they're suppose to be though so I ordered a new one but didn't change it yet. The muffler also has a couple of leaks. Could these holes be part of my problem? Can anyone point me in the right direction?
Chuck
Old Apr 26, 2010 | 12:26 PM
tesla440's Avatar
Check the air filter(s) & fuel filter(s) along with your collant level in the resevare & in the radiator when cold.
Old Apr 27, 2010 | 04:32 PM
got_soot's Avatar
Soot For Brains!
id run a compression test on it first. does it have a turbo on it?
Old Apr 28, 2010 | 08:53 AM
CLeger67's Avatar
No turbo, I just borrowed a compression gauge yesterday.
I pulled the exhaust manifold off and the cylinder closest to the driver was oily wet.
So, recapping what I've found out...Oil change lead to too much oil causing blow-by, adding oil to the bottom of the air filter. I pulled off the bottom of the filter canister and it seemed to have way too much oil in it. I emptied it out and drained the oil to the proper level. I primed the injectors by turning over the motor and cracking the fuel line at the injector. It will attempt to start with a shot of starter fluid and then die.
My plan today is to make sure the injectors are seated properly, then check the compression.
Old Apr 28, 2010 | 10:39 PM
got_soot's Avatar
Soot For Brains!
P.M me tomorrow, i will run by ya a few things.
ckt_santiago
Dec 26, 2018 03:55 PM
dieselfan
Dec 3, 2006 10:23 AM
whtractor
Aug 17, 2006 07:46 PM
Andyinchville
May 25, 2005 10:00 PM
Craig93
Jul 19, 2003 09:26 AM
