Help me put on a smoke show
I know the 3rd gens don't smoke that much but I have seen a few of them blow a nice cloud and I am trying to get mine to do the same. I have the Edge EZ and the hot Juice, cat delete pipe and an MBRP cool dual exhaust.
What settings are the best for smoke? I can pour a little out while driving and shifting gears (I have a 6 speed) but what I really want to do is blow some off the line once or twice. What settings are the best on the Juice/EZ and how do you guys blow smoke while parked, taking off from a stop, etc? Just looking for some pointers.
I cant speak for what setting you need to be on, but i can tell you how i get smoke
from a stop, if im in drive, i will just hold the brake down and give it a little throttle. It puffs out nicely there.
When taking off i just press the bottom of the pedal to the floor so its not floored, but like 75% throttle. it puts out a nice plume. if i floor it the tires will break loose easily.
On the highway i just let off the throttle and wait until i hear the turbo spooling down and then press the bottom to the floor again, about 75% throttle. it will smoke for hundreds of feet when i do that.
dj are you runnin stock clutch and turbo with that setup? I am thinking of going with the hot juice and ez or bullydog but knew my clutch wouldnt hold it and wasnt sure of the turbo, thanks for any info.
Okay, I have this smoke thing down pretty good now... I put the Juice on level 4 or 5 and just feather the throttle at low RPM's and dump a ton of fuel in. It smokes like crazy now.
barngal6
07-05-2009 06:49 PM
