Help with a HUGE problem!
If the stud is turning you can cut the flange off on the back side and pull it on through, or punch it on through, maybe. But I bet the threads are stripped and the nut is just turning and the stud is not. In that case, splitting the nut is an option. Try cutting it with a dremel as far as you can on both sides, then get a sharp chisel and see if you can split it off. Or, best of all, take a hole saw that just fits over the stud and cut a bigger hole in the nut. The nut will then slide right off and allow you to remove the wheel. Then cut the stud off near the flange and drive it out.
NEVER start nuts with an impact wrench. Whenever I see someone do that it makes me cringe and I know they don't care, or just don't get it. Way to careless and ignorant. Did I mention not to do that? And remember, don't do that!
Wetspirit
Wetspirit
From: Adirondacks of New York and Daytona Beach FL.
I agree with the small air grinder....I have cut off lug nuts from my 'ol 84 Dodge plow truck a few times.............zzziiiiiiiiiiiiiiiizzzzzziiiiiii izzzziiiieeeeeeee.
Done
Done
Tell your Buddy that your truck is not on PIT Road and you have lost a lot of laps and are out of the race.....
...a DNF for you and him---
Good Luck
...a DNF for you and him---Good Luck
1. At the dodge dealer to replace the studs
2. To do all this exciting extra work for being a ****
3. ....
STATUS UPDATE
Well, we managed to get a cutting wheel behind the wheel and cut off the two studs. Got replacement studs at Autozone, replaced the ones that needed to be, and now we're back to square one. Thanks to those who had advise!
Rick
Rick
shevygi
22
Jan 13, 2010 11:08 AM
emfc_22
21
Sep 25, 2006 06:40 PM
your buddy
"Put down the beer (and the impact wrench) and step AWAY from the truck!"
