Help Fast Please!!!!!!!
Old Feb 26, 2010 | 05:52 PM
SMKHZRD's Avatar
Hey guys i have big problem...so when i drive my truck and hit brake pedal it starts to chugg real bad then starts to climb in rpm while holding brake then thru it in neutral and revs to like 2200 to 2500 rpm then pops back down...took smarty off because thought nit was that but it is still doing it??????? please help.......
Old Feb 26, 2010 | 06:10 PM
Dodgezilla's Avatar
You may want to try resetting the APPS.
Old Feb 26, 2010 | 06:11 PM
bigwheels94's Avatar
Torque converter.
Old Feb 26, 2010 | 07:19 PM
SMKHZRD's Avatar
ya me and my buddy pretty sure it the Torque Converter it is locking up at idle which makes the motor chug then computer sees that rpm is low so it fuels which the harder u push brake more it fuels then when u let off it launches hard and the tc stays locked..... hey one quick question? When should the TC lock up? Is it in 2,3 and 4th... mine only locks up in fourth and it pulls hard..
Old Feb 26, 2010 | 08:08 PM
Spooler's Avatar
The TC locks up in 4th unless you are using OD lockout, then it will lock in 3rd. I think I remember reading they can lock up in 2nd with 2nd selected with the shifter, can't remember. You may have to mod the VB to do that. Just not sure.
Old Feb 26, 2010 | 11:38 PM
My truck (04.5) will lock @ 28 mph in 2nd as long as I select 2nd. Otherwise it will lock up in 3rd @ 48 mph with T/H on, or in 4th @ 48 mph with T/H off.
Old Feb 27, 2010 | 02:19 AM
rip 112's Avatar
Pardon my stupidity, but how do you reset the APPS???
Old Feb 27, 2010 | 06:43 AM
mikmaze's Avatar
pretty sure you disconnect both battery neg cables for half an hour, then reconnect, turn key to run, slowly press fuel pedle to floor, slowly let up, shut truck to off, then start truck. if there were codes involved in the truck leading you to try to reset, remember it takes several starts of the motor without issues to stop the code from coming up.
Old Feb 27, 2010 | 07:16 AM
BossHogg's Avatar
I had the same thing happen and it was the TC!
Old Feb 27, 2010 | 04:38 PM
SMKHZRD's Avatar
i have a billet triple disc converter lol (thought nit would be strong) took it down to shop today and that what they said it was...
Jim Lane
Dec 7, 2015 09:16 PM
EdmontonCanada
37
Dec 9, 2009 03:18 AM
Emoneysrt-6
Oct 21, 2008 11:17 AM
trik396
Mar 14, 2007 07:57 AM
Cummins Freak
Apr 5, 2006 12:54 AM
