Help with Dr. Performance Predator
Old May 28, 2007 | 06:45 PM
Bearwhiz's Avatar
I have the Dr. Performance Predator on my 06 that was installed by the dealer when I bought it. They screwed me on that price but that's another story. In reading the brochure I see you can add a switch that can turn the module off, turn it to performance or towing mode. Has anyone bothered to install this switch or is this just another money gimmick. It seems to me that if it can do three different functions then there should be two or three wires for the switch and not just one. Comments and suggestions are appreciated.
bearwhiz
Old May 28, 2007 | 07:28 PM
Nate-03 D's Avatar
Make sure you have the adjustable version. There are two Dr.Performance modules. One just plugs right into the MAP sensor and the other is adjustable. If yours is like the one I have it just plugs in the MAP sensor at that's it, what ever power the box adds is what you get, you can't turn it on or off unless it is removed.
What stage do you have¿
Old May 28, 2007 | 07:29 PM
973604x4's Avatar
on my unit, you can only wire up a switch for ON or OFF to the yellow wire.
Old May 28, 2007 | 08:25 PM
CReed's Avatar
My box the stage III version has three different levels stock is down, performance in the middle, and tow is up towards the side of switch with slash in it. It all runs off the yellow wire which can connected to the box and a ground wire.
Old May 28, 2007 | 08:46 PM
Bearwhiz's Avatar
I have the stage 2 and directions state that the switch will turn it off or put it in performance mode or tow mode.
Old May 28, 2007 | 10:53 PM
973604x4's Avatar
interesting. I'll be calling Dr. P.
Old May 29, 2007 | 01:35 PM
qzilla's Avatar
There should be 3 settings.
d0dg301
Sep 17, 2005 05:05 PM
nubby3
Aug 16, 2005 11:23 AM
CSAGrey1
Jul 11, 2005 03:40 PM
jumpinj
21
Jun 8, 2005 11:29 PM
Texas Crew'd
May 25, 2004 04:44 PM
