Help !! Boost bolt..which one to remove ?
Old Feb 26, 2005 | 03:03 PM
03CTDCO's Avatar
Hey I'm in the middle of finally installing my gauges. I need a picture of which bolt to remove
to add the boost bolt. Can I use any of the outside bolt locations ? Do they all end up
inside the intake chamber (high pressure)
Thanks
Old Feb 26, 2005 | 03:14 PM
big red psd cc's Avatar
Use the 2nd bolt from the back of the engine, on the valve cover side of the manifold.
Old Feb 26, 2005 | 05:00 PM
RamWheelsBy4's Avatar
Well looks like mine is 3rd from rear on engine side.
Old Feb 26, 2005 | 05:05 PM
030303's Avatar
I used the front, inside bolt. Closest to the front end and closest to the head. Easy to get at. If your using rubber tubing, be sure to put a zip-tie on it where it goes onto the bolt nipple, otherwise it might be pushed off by the pressure. And don't torque down too hard on the boost bolt when installing, they're easy to snap.
Old Feb 26, 2005 | 05:15 PM
03CTDCO's Avatar
Thanks everyone...got it
FordTrax
Apr 18, 2014 08:47 PM
RoadDiesel
Aug 7, 2012 06:06 PM
usmc2311
Nov 6, 2008 04:18 PM
12valveford
Off Road / 4x4
Apr 10, 2006 02:57 PM
Dodgezilla
Jul 17, 2004 05:24 AM
