Headlights
Old Nov 6, 2007 | 10:13 AM
donnee's Avatar
Headlights
Not sure if this is the correct thread for this.
Id like to change the stock bulbs on my 05 to Silverstreak or something else.
I dont want to change to projector or HIDs.
I know the headlight assembly pulls out.
Has anyone changed their bulbs and how much of a PIA is it.
Pics would be appreciated and mounting screw locations.
Thanks.
Old Nov 6, 2007 | 10:19 AM
vzdude's Avatar
DTR's 'Go to Guy'
LAMP
Disconnect and isolate the battery negative cable.
Disengage the three plastic retainers (3) that secure the rubber welt (2) on the inboard side of the front lamp unit (5) to the fender ledge.
Remove the three screws (4) that secure the front lamp unit to the fender.
Pull the lamp away from the fender far enough to access the wire harness connections (1) on the back of the lamp housing.
Disconnect the headlamp wire harness connector (4) from the headlamp bulb socket (5).
Disconnect the park and turn signal lamp wire harness connector (3) from the park and turn signal bulb socket (2).
Remove the front lamp unit from the fender.
Old Dec 30, 2010 | 05:24 PM
TxDiesel007's Avatar
Originally Posted by vzdude
LAMP
thank you for this very informative post!
Old Dec 31, 2010 | 05:37 AM
HMX-1's Avatar
My 15 year old did the ones in my wife's truck in just under an hour.
The SilverStars are now going in his new (to him) truck ...... '04 1500 Ram ST.
Kris
Extreme Diesel
40
Dec 25, 2006 11:23 PM
Hunter
13
Dec 20, 2002 05:59 AM
kingofdodge7131
Dec 14, 2002 02:43 AM
24
Dec 2, 2002 08:19 AM
