Have I made a bombing mistake?
Old Jul 20, 2004 | 08:14 PM
coolslice's Avatar
I finally broke down and got a TST pmcr. I know this box will shred my stock truck on the upper levels so I don't plan on running it at levels higher than 3. Keep in mind that I don't pull heavy loads and don't drive the truck like it is a vette. I just want a little more pep.
I was not planning on doing any major upgrades with the exception of maybe the tranny on down the road. Now I'm seeing that some people say you need a bigger turbo to handle the EGT and prevent the stock turbo from taking a dump.
Is there anything I need to watch out for or should I not use this box if I don't intend on any other major upgrades in the near future?
Old Jul 20, 2004 | 08:50 PM
Stingerpup's Avatar
That is one of the first BOMBing options for my new ride.
I am planning on installing guages, which is one of the things you should do, IMO. I don't believe you should worry about this being the only thing you do. As long as you have a good set of guages so that you can see what is going on with your EGT's, boost, and fuel pressure.
This is a very nice upgrade that shouldn't give you any trouble as long as you are able to monitor everything else that is happening with your pick-up.
Old Jul 20, 2004 | 10:19 PM
BCobb's Avatar
I ran the TST CR on my 03 auto for 20,000 miles no problems. I never went higher than 4X4. I now have a 04.5 6 speed and run it at 5X5 and still no problems at 750 miles.
Brian
Old Jul 21, 2004 | 04:35 AM
Dodgezilla's Avatar
A better exhaust, or at least a better 4" muffler, and a better flowing air intake are definitely in order if you're going to be running a fueling box too..
Old Jul 22, 2004 | 09:57 PM
DAYTRIPPER63's Avatar
I have had mine for a while now with stock turbo
As long as you have a good intake(AFE or?) and full 4" exhaust no cat and a freeflow muffler and the boost elbow fitting.
and guages to watch EGTs and BOOST you should be fine
Remember just because it has 9H.P. settings AND 9 TQ settings does not mean you have to use them...
I mostly run 2-2 or 3-2 and when I want to scoot 4-2 will do it
and when in traffic or just cruisin I run setting 1 (timing only) and at those settings with the set up listed in my sig. its hard to hit 1300 egt
Old Jul 25, 2004 | 07:52 PM
cr25ovet's Avatar
i have a question. people always recommend a better air intake. i would think if you let more air flow you will run lean and that means higher temperature. so my question now is why do we need an air filter system if we want the egt lower?? this is probably a stupid question i just don't get it?
regards
chris
Old Jul 25, 2004 | 08:32 PM
Gypsyman's Avatar
On the gassers too much air = too lean, on the diesels more air = cooler egt's...
steve1988
Nov 30, 2009 09:42 PM
hobbz
Apr 2, 2007 08:03 PM
gman07
Apr 8, 2006 08:30 AM
arcojet
41
Jan 25, 2006 06:17 PM
AKDSLDOG
Nov 7, 2003 07:55 PM
