hardware ?
Old Aug 31, 2009 | 11:37 PM
Ridgetop's Avatar
hardware ?
OK so I sheared a couple of bolt that connect the tranny support for lack of a better word. It is the rubber vibration isolator between the crossmember and tranny. So after going to four different hardware stores I cant find any grade 8 metric hardware or they have a very limited selection. The parts guy at the dealer told me they were 10mm X 30mm X 1.25 TP or 1.5 TP I cant remember. Ace had the correct size in grade 5 and stainless. My experience at work has proven stainless to be pretty tough. My question is what should I put in it ? The truck is on jackstands right know and I need to get it on the road asap. Pretty sad when you have to speacial order a metric bolt for you American truck. Phil out
Old Aug 31, 2009 | 11:43 PM
homewrecker's Avatar
I would say use what you can find to get it up and going. Then look for a nut and bolt store in your area. Not sure where you live and whats around but I know here locally we have 2 stores that carry specialty nuts and bolts and have never had a problem locating an odd size bolt.NAPA also tends to have a little better selection than most for automotive bolts.
Old Aug 31, 2009 | 11:50 PM
Ridgetop's Avatar
Cool yeah there is a speacialty store some where here in Santa Cruz CA. Lived in Raleigh for a while. I asked the Dodge dealer parts man if he could order them he said just go to the hardware store. I wonder what the stock hrdware for that app is ?
Old Sep 1, 2009 | 03:05 PM
Ridgetop's Avatar
Any one ?
Old Sep 1, 2009 | 03:13 PM
gadget's Avatar
Fastenal??
Worth a shot at least...
Old Sep 1, 2009 | 04:53 PM
tryNto's Avatar
Try a Cat or Cummins shop they use lots of Grade 8 bolts in many sizes...
Old Sep 2, 2009 | 04:50 PM
.boB's Avatar
How did you manage to shear them both off? You need to figure that out before putting new bolts in ther.
Old Sep 3, 2009 | 11:46 AM
XLR8R's Avatar
Is the dealer prohibitively expensive?
Often, their hardware is cheaper overall than going aftermarket, and they'll have the correct metric bolts in the strength needed (8.8 = Gr5, 10.6 = Gr8).
fredbert
May 16, 2005 09:40 PM
mr T
Apr 17, 2005 09:10 AM
spitzair
Oct 26, 2004 09:28 PM
Superduty12v
Aug 27, 2004 09:11 PM
