H2 Wheels
Old Oct 26, 2007 | 07:19 AM
gpshemi's Avatar
H2 Wheels
Looking for more information on running H2 wheels. Did a search, but I'm looking for somethign specific.
1) Does milling the centers to 4.775" ruin the chrome? The edge would be expose and more likely to peel in my mind.
2) Are the dodge wheels hub centric meaning I have to get that 4.775" right on the money?
3) Would these be good for towing my 5th wheel still? Concerned about the rating is all.
More pictures would be cool too.
thanks
Old Oct 26, 2007 | 07:26 AM
JCLeary's Avatar
1. Not Sure
2. No, the wheels are not hub-centric on a Dodge. The lugs are cone-shaped.
3. I would consider getting different tires, like a Toyo MT or AT, load range E
Old Oct 26, 2007 | 07:48 AM
gpshemi's Avatar
I already have tires rated for what I'm carrying. The BFG's while they are not E-rated tires are rated for the load. They've been working fine. I'd just move them over to H2 wheels. Found a new set for $500 locally. Might be able to get them a tad cheaper. Not sure yet.
Old Oct 26, 2007 | 08:35 AM
Hop's Avatar
Hop
So far on my h2's the chrome looks fine. Even if it did start to flake it's covered up by the center caps.
--Hop
Old Oct 26, 2007 | 10:48 AM
cquestad's Avatar
I have run them hard for 100k...love um. When you wear out the H2 tires...get some better ones.
Old Oct 26, 2007 | 12:08 PM
gpshemi's Avatar
I wasn't planning on running the H2 tires. It's $500 for just the wheels. I already have 285s to put on them.
Old Oct 26, 2007 | 12:28 PM
nitis's Avatar
gp I would look around you can get tires and wheels for 700 if you look and to me the tires are more desireable than the wheels
Also I would look in to running the 305 65 17 bfg if you like bfgs same heighth as your 285s but will fill out the wheel a little better
Old Oct 26, 2007 | 12:30 PM
nitis's Avatar
gp where r you located maybe i will pawn mine off on you already machined out.
Old Oct 26, 2007 | 01:16 PM
paroxysym's Avatar
milling the centers does not ruin the chrome. as far as for towing, id run a e range tire on them.
Old Oct 26, 2007 | 01:50 PM
gpshemi's Avatar
Maybe, but theres tons of guys running BFG 285's with 5th wheels. I'm not worried about that in the slightest. They're rated the for the same carrying cap as E class (3300lbs?). I won't be exceeding that.
The question was if the wheel will take the load. I know the tire will.
Old Oct 26, 2007 | 01:52 PM
gpshemi's Avatar
Well the BFG's are brand new that I have. I bought them and took them back 3 times trying to get them balanced out right. Turns out, after some argueing about road forcing them, that I have two bent stock steel wheels. These tires only have 7k on now.
I'm in Michigan
Old Oct 26, 2007 | 02:02 PM
paroxysym's Avatar
i wouldnt see why it wouldnt. i know there has to be a couple guys on here that tow with them.
Old Oct 26, 2007 | 02:18 PM
firemansdiesel's Avatar
What is the load capacity of the H2 Wheels?
Old Oct 26, 2007 | 02:23 PM
cquestad's Avatar
Enough...LOL.
Old Oct 27, 2007 | 02:40 AM
bigNtall's Avatar
Try this link for info on the modification
http://www.getdieselpower.com/my04do...h2install.html
