H2 Hummer wheels & 315's on my HO
I think these have about perfect backspace (5.5) with the 315's. There seems to be plenty of room between the inside of the tire and the lower control arm and no signs of rubbing. The mods require access to a CNC machining center to keep everything centered properly so balance isn't messed up. These are a very in-expensive way to get 315's on an 8.5 in. wide wheel that also looks great. I've only got about $690 in the whole set with new take off tires/wheels including re-mounting/balancing. I'm sure some of the polished or chromed H2 accessory wheels can also be modded the same.
The center bore needs to be opened up to clear the front & rear hubs. I also opened up the hub-cap bore to use the Ram cap. You can't use the H2 caps on the rear because the hubs stick out. I thought of ways to adapt the H2 caps but it seemed like more trouble that it was worth.
Kris
Kris
Originally posted by BigCarl
Do you have a front-end leveling kit on the truck? I would like to put the same wheel/tire combo on my 2003 4x4.
Kris
122mm is the machined size to fit the Dodge, HUMMER WHEELS ON EBAY
Hope this helps, look around they are cheap
