Got the skinny on rail pressure from Cummins!
Old Mar 4, 2004 | 10:55 AM
banshee's Avatar
Rod,
Did you try a run on level 9? Any bucking/missing from fuel starvation?
Thanks,
John
Old Mar 4, 2004 | 11:20 AM
doug's Avatar
AK -- on the TST, my understanding is that some trucks ransomly set a harmless crank position (I think) code as a result of buggy ECM programming, but that with this exception the box is rock solid. some stock trucks are setting codes at low rpm lugging conditions even (no box) . this is going to be an interesting saga to watch. With the duration and timing approach that is so attractive, I'm about ready to hang a code-reseting instrument on the OBD port and just clear them when they come. Maybe TST could hook up to the OBD port under the dash and automatically reset codes of certain types if they occur
Old Mar 4, 2004 | 03:34 PM
AK RAM's Avatar
Yeah, I guess that is always an option, but I would hate to have to go that route. I can pick up an OBD II at the local Schuck's Auto for $127.00. That should clear any codes...right?
Heard anything else about how the truck runs with this box? I remember seeing some folks report that it ran a little ruff. Kind of lost it's smoothness so to speak. Any speculation on what is causing that would be helpful.
Interested in the fuel starvation question from "banshee" as well.
Old Mar 4, 2004 | 04:11 PM
doug's Avatar
yup. most any OBD II scanner will work. I'm using Alex Pepers stuff (obd-2.com). I think I have a bad interface (gateway) but he's really good at making sure I'm happy. anyway I like this stuff because I can configure virtual gauges and monitor cool stuff on my laptop.
I've got the same interest as you re: rough running. so far, the only comments I've heard are that the higher settings may cause this -- one guy had such exhaust manifold pressures he was floating valves. engine not happy. but thats just because this box (on level 9) gives more than the stock air supply can handle. I know Rod reports very nice enjoyable power.
Old Mar 4, 2004 | 04:16 PM
Push Rod's Avatar
From: Drive till ya hit a Polar Bear, then go back 50 miles
Originally posted by AK RAM
Off topic I know, but has anyone received any new information on TST's progress with the PMCR? Still code issues?
So we can get this thread back on track, I'll post some additional information back in the PowerMax CR thread that has kind of went away....
Rod
Old Mar 4, 2004 | 09:09 PM
AK RAM's Avatar
Rod
You da man.
jj3500
Jul 11, 2008 02:35 PM
5.9Excursion
Mar 13, 2008 10:56 AM
barracuda
13
Mar 30, 2006 09:39 PM
tanderson2002us
Oct 15, 2003 10:24 PM
rattle_rattle
Jul 30, 2003 07:40 AM
