Got my Ramifier
Old Feb 18, 2005 | 04:18 PM
blown32's Avatar
Got mine today as well. I am sick as a dog so install will have to wait until I can go a while without purging myself. Even if I could get it installed, I would have a hard time driving right now.
I can't wait to instal and test. I have a Power Pup as well and really want to see how they compare. I took the Pup off because of bad weather and slick roads (way to much tire spin) and a slight loss of MPG. Having the RAMifier with in-cab adjust will be just the ticket Also can't wait to report on the MPG with the RAMifier.
Hope I feel better tomorrow so I can come out and play
Allen
Old Feb 18, 2005 | 04:29 PM
rockjeep's Avatar
I own an electronics company so extending the length of the harness will not be an issue. Oh did i mention that my edge ez has been in cab adjustable the whole time I've had it. Up in the snow its nice to be able to power down and keep the tires from spinning.
Kory
Old Feb 18, 2005 | 04:45 PM
PThree's Avatar
Can you make and send me some of that cable then lol.
Old Feb 18, 2005 | 04:52 PM
rockjeep's Avatar
Still waiting on ups, but I wil see what is into doing the harness. The ez one is not stright foward. I laid out a printed circuit board to do what I needed. You can't use a rotary switch to change the switch settings on the ez.
Kory
Old Feb 18, 2005 | 06:54 PM
Rod meyer's Avatar
Still waiting for mine. I'm here on thr left coast so it may take a exra day or two.
Old Feb 18, 2005 | 08:08 PM
PourinDiesel's Avatar
Got mine.
The RAMIFIER has alot more bottom end than the EZ it replaced.
Thanks Dennis@TS!!
Old Feb 18, 2005 | 11:49 PM
stxr's Avatar
I wanted my switch out of sight of the wife just incase she wanted to mess with it. I pulled out the ash tray and removed the liner and then drilled a very small hole just big enough for the shaft to stick through and reinstalled. I did not put the liner back in but I don't smoke any way. Now it is out of sight and just open the ash tray and give it a twist.
Gary
Old Feb 19, 2005 | 03:08 AM
AK RAM's Avatar
Explain the in-cab adjustment to me as I'm getting mixed information. Is it a smooth dial or auditable "click" so you know which setting your on? If there is a "click" for each setting, how much HP per click….or what are each setting?
Old Feb 19, 2005 | 05:40 AM
smooth.
Old Feb 19, 2005 | 07:13 AM
odie2219's Avatar
Have not installed mine yet( waiting on gauges, march 1st). For those who have already installed the Ramifier, Does it effect the overhead readout(mpg)? Any increase in mileage(I know it's to early to tell)?
Odie
Old Feb 19, 2005 | 09:52 AM
SportTruck's Avatar
#7 Here. have not installed mine yet only because im having my trans worked on again, broke reverse band. But I will be mid week. Im glad to hear it has more bottom end than edge, as I will be swapping out my stack. Thank you TS Performance!! Good to know there are still good guys in the world today!!
Old Feb 19, 2005 | 11:07 AM
DieselRaptor's Avatar
Smile
I received mine last night (#2 on the list). I will install today . Does anyone know the proper procedure to stack the Ramifier w/ the power pup? I know to take the pup back to stock first, but what then?
Edit: OK I went out and installed it and answered my own silly question. What I meant to ask is in which order do you plug into the Outlook?
I would like to thank (again) Dennis also.
Scott
Old Feb 20, 2005 | 06:25 PM
BCobb's Avatar
PourinDiesel,
How's the TST cr with the Ramifier. I have a buddy who has the TST cr on his 04.5 and his clutch is holding so far, so I thought I would try it on his truck to see if I like the combo also he wants to see how much the clutch will hold. I have been thinking of getting the TST cr, but now that I have the Ramifier comming not to sure.
Thanks
Brian
