Got my gauges installed!
Old Aug 28, 2005 | 01:20 PM
Dieseljunkie's Avatar
Yup, we had a DTR Chapter 24 bomb/bbq yesterday, and it was a great time! We didn't have a lot to do, but it took most of the day. Putting in gauges is a very involved process. A great time was had by all, even if it was 103*. I went with the Isspro gauges that match the factory dodge gauges, and I put them on the A pillar. Also, we ditched my muffler, and I went to a straight pipe. All in all, I really like the way everything came out.
On to the pics:
Here's the fuel isolator location:
Here's the drilled and tapped exhaust manifold for the EGT's:
Here's the elbow drilled for boost:
Here are the gauges alone, installed:
Here are the guages along with the factory gauges to compare thier looks:
And while Cowhand was getting all that done, Gerry and I were ditching my muffler and replacing it with this:
After the stuff was done, we cooked up some carne asada and pollo asada, and had some beers and watched the bristol race on Cowhands BIG *** tv! It was a great time, and I can't wait to do it again. There is something about this board that brings comeraderie. When I pulled up to Cowhand's house, we were talking to each other like we'd known each other for years, with no qualms at all, yet, yesterday was the first time we'd actually met. All in all, I had a great time, and Id say the 2nd #24 chapter get together was a sucess.
Scott
Old Aug 28, 2005 | 01:29 PM
gerry's Avatar
Had a great time.. and thanks to Cowhand and Mrs cowhand for being great hosts...
Guess it is time to buy my guages... Think I have the locations figured out now...
Gerry
Old Aug 28, 2005 | 08:16 PM
drew03's Avatar
is that a homemade muffler replacement pipe, if not where can i get one??
Old Aug 28, 2005 | 08:40 PM
The pipe was actually given to me by Bama on here.. Not sure if he had an exhaust shop make it up for him, but usually, you can get any muffler shop to make you the pipe for $50.00 or so.
Scott
Old Aug 28, 2005 | 08:46 PM
bama's Avatar
id gladly have given 50 bucks fer somebody to do it for me...i bought a 4 ft stick of 4 inch and welded it myself.the stick ran 40 bucks here,but,scott sounded like he needed a sponsor ........bama
Old Aug 28, 2005 | 10:13 PM
Bama: I needed a sponsor in the exhaust dept. thats for sure! I love the way the pipe sounds, and so far I have no regrets.. While empty, the drone isn't bad at all. We'll see how bad the drone is when towing a load, but I don't tow enough to make it matter so much. Im loving the new sound.
Upon my drive up the mountain, under normal driving, my EGT's got to 1200 very breifly, but I made sure not to go above that.. the temps sat between 900-1000 most of the time.
Scott
Old Aug 29, 2005 | 12:46 PM
Cowhand's Avatar
I shoulda known by looking at it that bama had his grubby little donut snatchers on it....
At least I washed my hands after I touched it.
Old Aug 29, 2005 | 07:03 PM
bama's Avatar
Old Aug 29, 2005 | 08:08 PM
Red1ton's Avatar
Hey ! Dieseljunkie..am thinking of putting in the trans. and diff. heat gauges (with the new pan, and cover) in mine, did you buy the wire harness, when you got the gauges or did you wire it yourself?
Old Aug 29, 2005 | 08:10 PM
I didnt buy any extra wiring when I bought the gauge setup from www.dieselmanor.com, but Cowhand had some extra wire on hand, which we used, and I had to make a trip to the hardware store for some spade connectors, but other than that, I didn't need any other wiring harnesses.
Scott
Old Aug 29, 2005 | 10:58 PM
Jeff in TD's Avatar
Hey, I'm about to install one of the new style Isspro EGT's myself... and had a couple of questions.
Where did you guys decide to mount the circuit box?
Where was it most handy to connect to ignition switched power?
Old Aug 29, 2005 | 11:53 PM
We mounted the circuit box under the dash with some zip ties. We tapped into the headlight wires in the panel behind the headlight switch. We tapped into the dimmer wire, so the gauges would dim at the same time as the factory gauges. The wire was orange with a black tracer stripe.
Scott
Old Aug 30, 2005 | 01:11 PM
Jeff in TD's Avatar
Thanks Dieseljunkie.
I think I have the lighting wire figured out (orange with white stripe in my year, I believe).
I was more interested in the keyed power source you used, the one for the red wire from the circuit box?
Is there a spot in the fuse box or some place intended for keyed power for accessories, or did you tap a wire under the dash somewhere?
Old Aug 30, 2005 | 05:34 PM
Cowhand's Avatar
I tapped into a pink and some other color (orange tracer?) under the steering column....
Easy to find with a test light.
Old Aug 30, 2005 | 10:34 PM
yup, he did the wiring, so he knows whats up with the wiring.
Thanks Conrad
Scott
