Got boost..
Old Oct 20, 2007 | 02:39 PM
Billm2004's Avatar
Got boost..
Im tryin to get my guages in and im not sure where to get power for the lights in the guages. i would like them to be able to dim with the dash lighs, any ideas?
And where should i tap in for my boost guage tubing
Old Oct 20, 2007 | 09:49 PM
hump's Avatar
Mine is tapped into the actual light switch/dimmer behind the light switch cover.
Boost can be easily hooked up if you have a boost bolt. The boost bolt replaces one of the factory bolts & the tubing hooks up perfectly to the new boost bolt.
Old Oct 20, 2007 | 09:54 PM
3500CTD's Avatar
Switch-headlamp - Black 10 Way Cav Circuit Function
1 L116 20wt/lg Headlamp/fog Lamp Switch Signal
2 E2 20or/br Panel Lamps Dimmer Signal
3 L115 20wt/yl Headlamp Switch Return
4 E19 20or/br Headlamp Switch Dimmer Signal
5 Z407 20bk/or Ground
6 L914 20wt/lg Cargo Lamp Switch Signal
7 - -
8 - -
9 - -
10 - -
I just saw this in another thread. should be #4 oarnge and brown wire on the back of the headlight switch. Someone will correct me if im wrong.
Old Oct 21, 2007 | 12:13 AM
Billm2004's Avatar
7 - -
8 - -
9 - -
10 - -
You were right it was the orange and brown wire. I have C2 guages so they didnt really dim too much and are kind of bright right in my face. If anyone is thinking of putting these guages in a piller mount, ide go for another type of guage, ther are REALLY bright!
Old Oct 21, 2007 | 08:08 AM
MikeyB's Avatar
You can get a little potentiometer from Radio Shack and install in the pillar so the gauge lighting can be fine tuned.
MikeyB
Old Oct 21, 2007 | 11:36 PM
soulezoo's Avatar
DTR 1st Sergeant
MikeyB
Do you have a part number for our challenged radio shack sales people?
Old Oct 22, 2007 | 07:16 AM
MikeyB's Avatar
No, I sure don't. Just have to rummage through their parts bins for one.
BTW, here's Autometer's solution for dimming the LEDs on the C2 series gauges.
http://www.autometer.com/cat_accesso...l.aspx?vid=185
MikeyB
Dale M
Mar 5, 2011 03:40 PM
bhoff1175
Jun 7, 2006 10:19 PM
Begle1
Jul 13, 2005 04:13 PM
joel
May 23, 2003 07:02 AM
crankbait
Feb 14, 2003 04:31 PM
