Good single
Old Jun 25, 2008 | 12:22 PM
  #31
jwb600's Avatar
madhat I would stay around that 62 you are looking at maybe a 64. you can use that in a twins setup later also and it will still be really drivable. I had a sps 66 on my 05 and it did ok but the bigger you go the worse its going to tow in my opinion. if you end up with something bigger like a 66mm injectors help out alot to get it lit up. good luck on your search
Old Jun 25, 2008 | 05:52 PM
  #32
pos dodge's Avatar
Originally Posted by wap
I just looked at the add in DP, and it says that HP varies depending on fuel system, injectors, intake and other factors. Considering other factors, I am sure you make 700hp with no2, no problem.
And also I want to clarify that I am not bashing ATS or their products. I just dont think it is realistic to expect 700hp on fuel with such a small set of twins.
Just looked at ATS's website and they dont show the 2k/5k anymore, its the 3k/5k.
No they dont. But i found one new that a guy had bought and it was for the wrong motor. He had it for about a year he said. Ats said they quit making them about 6 months ago. Thats the history behind it. Theres not much difference if you do the research. I know every bit helps though. I think its like 100 cfm's more and the boost is a little higher. Both non wastegated, dont know how that would work with twins to begin with, unless you buy a blowoff valve or something. Still researching on turbos, its a never ending journey it seems.
Old Jun 26, 2008 | 11:26 AM
  #33
cquestad's Avatar
The cast elbow hot pipe from primary to secondary has a wastegate in it.
The A5k is not wastegated...neither is my S-480...it does not need to be unless you are overspeeding your secondary or making too much boost.
The ATS twins are nice...
nasty01cummims
Jun 29, 2009 09:59 PM
xOmertAx
19
Nov 13, 2007 01:19 PM
whatdieseltoget
13
May 14, 2007 12:54 PM
12valvesmoker
Oct 17, 2004 10:09 PM
tons0torque
Feb 12, 2004 04:55 PM
