Goerend question
Old May 20, 2009 | 08:47 PM
Richie7448's Avatar
Goerend question
I got a goerend trans installed tuesday, I know the shifts are firm but dang! So I checked my fluid and it was too full, I know this is really bad and I'm gonna drain before I leave work, but could this cause harsh shifts? TIA. Richie
Old May 20, 2009 | 09:15 PM
Spooler's Avatar
How are you checking the fluid? 48re does better a little overfilled. Are you talking about the harsh 4th gear lockup? If so, you will learn to drive around it. No biggy.
Old May 20, 2009 | 09:40 PM
Richie7448's Avatar
I checked it at operating temp in neutral on flat ground. The fluid comes almost an inch above max.
Old May 20, 2009 | 09:49 PM
Spooler's Avatar
Yikes, drain a little out.... Somebody got overzelous with the tranny fluid.
Old May 20, 2009 | 09:59 PM
Richie7448's Avatar
Believe me, I'm gonna. You think that could be the cause of my problem? Pretty much every shift under light acceleration is harsh.
Old May 20, 2009 | 11:32 PM
67HotRod's Avatar
Dave told me a little overfilled is fine, no problem.
Old May 21, 2009 | 04:31 AM
Richie7448's Avatar
Well I took out about a half quart and that seemed to make it a lot better. Spooler, does the 4th gear lockup shift pretty hard on yours? Thanks guys.
Old May 21, 2009 | 07:17 AM
KKB's Avatar
KKB
When Dave installed my tranny he said that these trannies do better overfilled so I personally wouldn't worry. He overfilled mine on purpose.
Old May 21, 2009 | 08:37 AM
Spooler's Avatar
It can be if I get it wrong with the go pedal..LOL That's what billet input shafts are for....
Old May 21, 2009 | 09:13 AM
cincydiesel's Avatar
The 4th gear lock up it pretty harsh but you'll learn to deal with it.. Dave also recommended that I leave my tranny a little overfilled. I've just learned to ease out of the throttle during the 3/4 shift
Old May 21, 2009 | 12:10 PM
blacksmoke06''s Avatar
Same here with the overfill on the tranny. I was out at his shop a couple weeks ago and Dave said that he likes to overfill these trannys a little. Just like cincydiesel diesel said I ease out of the throttle a little bit to make the shift a little smoother, you get used to it pretty quickly though.
Old May 21, 2009 | 02:58 PM
Richie7448's Avatar
Thanks guys, I really appreciate it.
Old May 21, 2009 | 03:38 PM
mikmaze's Avatar
as long as you are not seeing foamyness when you check it, I was told it is not too full.
DodgeRamdiese01
Jul 26, 2008 01:43 PM
ontheedge
15
Apr 17, 2006 07:20 PM
Cowhand
40
Mar 9, 2006 06:20 AM
Cowhand
Jan 12, 2004 08:54 PM
Cumminsdieselboy
18
Jun 6, 2003 10:54 AM
