glacier diesel big line kit
Old Jun 19, 2007 | 06:50 PM
450r's Avatar
what do you guys think of this kit as a starting mod to add later with programmer and lift pump kit
Lose that restrictive line from the fuel filter housing to the injection pump and let your fuel system flow at it's full potential! The GDP Big Line Kit is an excellent addition to our GFS Performance fuel systems. Gain 2-3 psi right where you need it, at the injection pump inlet!
http://www.glacierdieselpower.com/pr...?pf_id=0306BLK
Old Jun 19, 2007 | 06:54 PM
ptgarcia's Avatar
Good mod. But go ahead and add the filter and get the MK-2 + Big Line Kit. I'm diggin' mine.
Old Jun 19, 2007 | 07:34 PM
450r's Avatar
hey thanks i totally missed that setup any other reviews or experiences
Old Jun 19, 2007 | 07:58 PM
motrapper's Avatar
yes just put it on my 05 before a 2000 mile trip and no problems the one suggestion is pushing it over the barbs on the connectors on acouple i only go it over 2 of the barbs but check it all the time and its good
going to put it on my 07 mega i just bought this month better filtration is always a good thing just
Old Jun 20, 2007 | 07:38 AM
lniemeyer2's Avatar
The trick to getting it over the barbs is soaking the end of the hose in HOT,HOT water berfore putting it over the barbs. Learned that from the Glacier folks after struggling for hours trying to get the hoses all the way on.
Old Jun 20, 2007 | 08:05 AM
04ctd's Avatar
we microwaved a coffee cup of water boiling hot, and put hose in that, then over barbs.
pictures somewhere in that jumble in my sig links, we put one in Mad's truck.
his did not come with the Fuel filter adapter, though, ??
so we had to leave the stock lift pump on, and push through it.
he had around 25 psi last time i rode in it.
Old Jun 20, 2007 | 10:22 AM
Thundercloud's Avatar
For those of you that did the install yourself on the MK-2 + Big Line Kit, how much time did it take to install it and how hard was it?
Old Jun 20, 2007 | 10:35 AM
ptgarcia's Avatar
It's really easy, just a bolt on affair. I probably spent two hours on it, which means a good wrench can do it in one.
Old Jun 20, 2007 | 10:46 AM
JORDAN's Avatar
sorry to hijack but, do I need to do a lift pump upgrade to run this kit? I have an 06 w/ pump in tank? I would really like to get a 2mic setup but don't want to change the lp. thanks
Old Jun 20, 2007 | 10:48 AM
ptgarcia's Avatar
No. I'm running mine without a lift pump upgrade.
Old Jun 20, 2007 | 01:17 PM
JORDAN's Avatar
cool thanks
Mechanos
Jan 22, 2009 11:25 AM
06CTDforAU
18
Jun 25, 2007 05:47 PM
ptgarcia
Aug 18, 2006 03:52 PM
Raspy
36
May 23, 2006 10:28 AM
