Give me your thoughts
Hi qzilla,
I like the look and the sleek design. The rounded edge along the right side is a nice touch compared to earlier designs. Albeit, I am very pleased with the performance of my Commander, I am looking forward to more details regarding this product.
That looks good. Are there different options of back lighting? Ever think about a wireless design?
Keep up the good stuff!
Yes we thought a lot about a wireless display, and we chose the best one built to date, the iPhone/iTouch. Have you heard about the iQuad yet?
Do a google search for "Quadzilla itouch" and you should get plenty of results.
What does it do?
This is the new display that will take over the Pulse and Scouts.
For the Pulse is has double the memory, buttons are mechanical now, has a built in AMPS mounting pattern on the back so that it is compatible with tons and tons of mounting options such as windshield mounts and dash mounts.
We also added a connector so those that need to use the USB port can take it out easily and take it into the house.
It also looks much better and sleeker, will be even more reliable and have more features.
With double the memory we can add more custom tuning features, more parameters, more data logging, better menu systems and will handle more vehicle models such as the new 6.7L dodges and all the regeneration stuff.
On the Scout side it has many of the same features plus, built in Turbo Timer (not add on) plus all of the regular things like EGT, Boost, Trans in many cases and all the obd2 info. It also can be added on to for things like Fuel Pressure and user defined 0-5v signals.
How much does it cost?
Most buy the Pulse included with the Adrenalines and we do not expect the price to go up.
The Scout could be a few bucks more but, nothing too major. Just like now the EGT and FP kits are add on kits. Everything else is included.
Looks nice but have you found out anything about the xzilleraider II for the 04.5 half trucks. I havent seen any posts about it lately.
Ok, I'm slightly confused, looks lots like the Edge Insight that I have. For what its worth, I really like my insight, initially the screen seemed small, but now its fine...
Does a bunch of stuff the insight won't do especially on your 6.7L. Things like manual regen, constant regen monitoring without you selecting as a displayed item. We handle that with specialty icons that popup automatically when it goes in to passive or active regen. We also have the "flips screen" which allows you to setup 2 whole displays and use 1 button to toggle between them.
Also now have the Turbo Timer and we have always had the fuel pressure monitoring option.
Fancy pictures...
I know the Pulse is coming first and is expected around the end of the month ish.
Scout is actually a LOT different than what we have now because everything is 100% self contained in the display including the TT parts so it will be longer. Sometime in May I would expect.
qzilla you just wrote a post about the x2 and the surging problems that everyone is experiencing with it. You asked for a few people to send them in so you can test out a new tune that might fix all the problems that peeple where having with it. I was just wonderingif you have found out anything about the tune so I can get mine fixed.
