geno's mpc-eliminator pipe question
in geno's part # mpc-ep. it replaces the tube from the air filter housing to the turbo, without the silencer. anyone here use this? good/bad? thanks in advance,
I would use the airaid MIT over the MPC any day of the week. The MPC is a straight piece of metal, yet the upper and lower elbows are different size, the MIT makes a smooth transition from the large upper to the small lower, thus increasing airflow and reducing turbulence, where the MPC would promote turbulence.
Either way be sure to leave the vanes in the lower elbow, they are supposed to increase the turbo efficiency up to 30%.
with the 2 pics, the airaid does appear "smoother". my question is, out of a stock air box, and filter, will the turbo be starving with air at all with the geno's? that size tube can move a lot of air.
The tube will only move as much air as the lower elbow can accept, which is the same size as the MIT lower diameter, and smaller than the MPC.. So you induce turbulence.. The MPC is larger around at the base than the lower elbow is (inside dimensions).
You are not going to "Starve" the turbo of air with either of those. Either one has to be better than the stock design. I made my own torque tube using smooth rubber elbows that I bought at airflowonline. The factory accordion type elbows are not smooth inside....
