Gear Ratio's?
Old Mar 18, 2008 | 04:21 PM
BossHogg's Avatar
Gear Ratio's?
Other than checking RPM at certain speeds, what is a sure fire way to figure out what rear end you have??
I talked to Dave Goerend and he said its usually on the rear diff cover on the left side, but I didnt see anything, only the level marker on the center of the diff cover.
I was told I have 4:10 gears at the dealer, but a buddie of mine doesnt think I have them. Just want to make sure with the Goerend tranny on the way!!
Any think I can check on the truck...its not listed on my sales sheet?
Old Mar 18, 2008 | 06:20 PM
92'1stGen's Avatar
Put a mark on the drive shaft and mark on the bottom of one of the tires. Move the truck forward one full rotation of the tire and have a buddy count the rotation of the mark on the drive shaft. If it rotates about 3 n 3/4 then you have 3.73's, if it rotates a little over 4 then you have 4.10's. The bigger tires will make the rotation of the drive shaft's slightly off from what they would be from the factory so you'll have to compensate but it's the same principle.
Old Mar 18, 2008 | 06:29 PM
ptgarcia's Avatar
The bigger tires won't matter. One rotation is one rotation, no matter the radius of curvature. What will change is the distance traveled through that rotation.
Old Mar 18, 2008 | 06:31 PM
durasnack's Avatar
what is your rpm at 70?
theres a code in the glovebox that should tell you as well.
Old Mar 18, 2008 | 06:45 PM
BigB82789's Avatar
Should be in the glovebox along with the paint codes and other options.
Old Mar 18, 2008 | 07:01 PM
mulisha's Avatar
2200 rpm's at 70 there 410's
Old Mar 18, 2008 | 07:32 PM
ThatGuy34's Avatar
you can email chrysler and request a build sheet, or call a dodge service department and they can look it up
Old Mar 18, 2008 | 11:32 PM
BossHogg's Avatar
I looked and it was posted in the glove box....never seen that before! Ha.
I told the guy I wast buying one without 4:10's and he swore it was...whatever, its pretty perfect....any higher and the price to drive would be too much.
design
32
Jun 23, 2003 10:07 PM
mbw
Mar 5, 2003 05:38 AM
Garz
Feb 3, 2003 09:08 AM
Cutthroat
Jan 8, 2003 09:37 AM
accordionjohn
Oct 7, 2002 12:54 PM
