GDP Tuning Kit
Old May 30, 2007 | 03:11 PM
lcaad1249's Avatar
GDP Tuning Kit
I'm trying to get my Glacier system to put out around 30 # fuel pressure. Does anyone know which shims will get me close?
Old May 30, 2007 | 03:43 PM
GOT BOOST?'s Avatar
Hey man i did this just the other day. One big shim .040 and two little shims .020 it made me 27.5 to 30 psi. By the way PM me i got a question. Jay
Old May 30, 2007 | 04:32 PM
lcaad1249's Avatar
Thanks, I changed it once. Couldn't get it to change off of 20 pounds no matter what I did. Finally figured out the the isolator needed more antifreeze and found I'm pushing 57#. Time to change.
Old May 30, 2007 | 04:42 PM
O.T's Avatar
O.T
Jay is there a benefit to running 27-30psi. I have my Glacier kit set at 20psi.
Tunning kit is sitting in my tool stand..lol
Thanks
onetun
Old May 30, 2007 | 04:52 PM
Pooter's Avatar
Thanks
onetun
Are you running the 2micron kit from them, or is it still going thru your stock filter housing?
NM, just saw your sig.
Just make sure if you run more pressure with the stock filter housing to get the billet cap for it(I believe if youre running more than 25-30psi, but not positive)
As far as more pressure, more fuel I imagine theres a point of diminishing return if you still have stock injectors/cp3, etc
I plan on getting the glacier kit sometime, when money allows...
Old May 30, 2007 | 06:21 PM
Rpainter's Avatar
I am running 42 psi with stock filter lid and no leaks
Old May 30, 2007 | 08:08 PM
lcaad1249's Avatar
When I got my CP3 modded from Floor-it they recomended 30#'s. I did Got Boosts recomendation and ended up with 32#'s at idle.
Old May 30, 2007 | 09:47 PM
GOT BOOST?'s Avatar
Yeah, John recommends running 30 psi. I got the billet lid from genos. Glad to see I could help you out. Jay
Old May 21, 2008 | 08:27 AM
5.9Excursion's Avatar
I was running around 22 psi with it as supplied from gdp. Going off the advice above (can't find any directions from Glacier on the tuning kit?), I replaced the 0.020" shim that was in it with a 0.040 and (2) 0.020 shims, so basically 0.080" of shims. Pressure is now 25 psi at idle.
Maybe I should have left the original 0.020" shim installed to get closer to 30?
Who has used the stiffer spring supplied with the kit? What will that do to the pressure (how much of an increase)?
Old May 21, 2008 | 08:32 AM
Billm2004's Avatar
im using the stiffer spring with the shims that were in it, and im at 41-42 psi.
Old May 21, 2008 | 10:22 AM
soulezoo's Avatar
DTR 1st Sergeant
I used the stiffer spring, I think .080 worth of shims and putting out 32psi to the Floor it stage 2 pump. John did recommend pressure in the 30's. what I found was that when I went to WOT, pressure dropped to 22psi which is right smack in the middle of the peak flow rate (volume) for the walbro... ideal!! That said, I now have a 200gph FASS... someone need a walbro?
Old May 21, 2008 | 10:43 AM
2003Ram's Avatar
I could use it. Are you selling cheap?
MRoman
Oct 6, 2006 09:33 AM
checkster
Sep 22, 2006 09:30 PM
acook
Sep 21, 2006 03:44 PM
SolarYellow05
Sep 10, 2006 09:14 AM
SSminnow
May 23, 2006 10:21 AM
