Gauges installed, EGT's quite higher than 2nd Gen Truck
Old Mar 25, 2006 | 02:54 PM
barracuda's Avatar
I just got the Boost, Fuel and Pyro done on my 06' and I was surprised how quick it will hit 1000 degrees completely stock. My 2nd Gen w/ mods hit around the same time but w/o mods on the old truck it was a challenge to hit 1000 degrees empty. Just thought I would share this, truck only has about 450 miles maybe that is why. New one is a 06' 3500 DRW QUad/4x4/Auto ( I need to update my sig)
Old Mar 25, 2006 | 03:30 PM
HighTen's Avatar
That sounds like my truck. It is stock and it will go up to 1000 empty easily. I think the 04.5 and up trucks are able to take a lot of heat without getting damaged.
I have towed a 8000 lb travel trailer a lot and the truck has spent some time with the EGT at 1200 deg and nothing bad has happened. In fact, the towing and getting hot only seems to give it more power and better fuel economy.
It seems to me that you shouldn't be able to get your truck too hot if it's stock no matter what. Just think of how many people have diesel trucks without gauges.
Old Mar 25, 2006 | 11:46 PM
Spooler's Avatar
All I have to say is MEOW, MEOW, on all 04.5's up. EGT's are normal.
Old Mar 26, 2006 | 08:41 PM
bigwheels94's Avatar
Ditto for mine.
My stock engine runs at 1100 degrees when pulling hard all the time.Only 13K on it so far but had no problems yet.These temps are post turbo!!As a Cummins Marine dealer I think they are too high,but so far I haven't been able to get spec.'s on this engine from either Dodge,or Cummins.
Old Mar 27, 2006 | 07:38 PM
Angry Cummins Says!
I was finally able to weasle some info out of the Cummins rep.He says the Max.EGT.for the 04.5 & later engines IS 1100 degrees!!!Post turbo temp.The rest of the info I wanted was "Cummins Classified"!!!
Old Mar 27, 2006 | 07:50 PM
barracuda's Avatar
That sounds about right post-turbo, that's around 1250-1300 pre turbo..same as the older trucks
steveb
16
Dec 20, 2006 05:47 AM
Saggy
Jul 3, 2006 12:25 PM
Eskimo
Mar 11, 2006 05:57 AM
t_george77
Nov 23, 2005 02:19 PM
jerry007
Oct 28, 2004 08:24 AM
