Gauges for '06
Old Mar 27, 2006 | 09:12 PM
TonyB's Avatar
Gauges for '06
This has probably been asked, and I searched, but here goes....The truck is stock & I have no intention if installing go-fast-goodies. FYI...I'm not having any issues, just want to learn what the normal range is so I can buy appropriate gauges.
I would like to know the normal pressure & temp ranges:
Fuel Pressure: 7-10PSI?
Boost: 0-30PSI?
Oil Pressure: 10-50PSI?
Water Temp: 180-220F?
Trans Temp: 140-190F?
Diff Temp: Ambient-230F?
Pyro: <1300F?
Anything I missed?
TIA
Tony
Old Mar 27, 2006 | 09:24 PM
Benson's Avatar
That's pretty close. Most fuel pressure gauges will go 0-30.
Most oil pressure will go 0-80, water and diff up to 0-250. Trans to 280 or so.
You could go 0-60 on the boost, might as well. Many a stocker driver has been bitten with the power bug. I'm going to ad a module of some kind but that's about it--along with better breathing plumbing--already done.
I'm getting ready to install mine soon. Most are Di-Pricol, a couple of VDO's and 1 Auto Meter.
Old Mar 27, 2006 | 10:47 PM
qzilla's Avatar
Unless you have specific places for all of the analog gauges, this might save a ton of money.
The only thing is won't do is the diff temperature.
http://www.quadzillapower.com/commander/index.html
Old Mar 28, 2006 | 09:05 AM
TPilaske's Avatar
What's the price on that unit? You can PM me if you want...
Tony
Old Mar 28, 2006 | 09:08 AM
texaspower19's Avatar
Boost: 0-30PSI?
Pyro: <1300F?
Anything I missed?
TIA
Tony
youll wanna go biger than thirty on boost. i can hit thirty stock.
Old Mar 28, 2006 | 10:24 AM
davelinde's Avatar
as noted... trans temp can hit 250 or 260, eg backing a trailer into a tight spot...
I'm in the market for an FP gauge myself and it looks like the common ranges are 0-15 and 0-100 with fewer 0-30... is 0-30 the right size for a stock setup or is 0-15 ok?
Old Mar 28, 2006 | 10:33 AM
TonyB's Avatar
Thanks for the replies!
Here's what I'm planning: 3 gauges
1) Pressure, 0-100psi
2) Temp, 140-250?
3) Pyro
All gauges will be electric. The pressure gauge will switch between OIL, Boost, and Fuel. The temp gauge will switch between water, trans, and Diff. The pryo will be dedicated.
I am leaning towards full sweep auotmeter electrics.
Any thoughts?
Tony
Kman9090
29
Dec 6, 2007 06:43 PM
coontz0473
17
Sep 22, 2006 03:52 PM
Duckman1993
Sep 12, 2006 07:50 PM
estesbubba
Jul 18, 2006 04:35 PM
AggiePhil
Jan 30, 2005 01:15 PM
