gas gauge light out
Old Sep 8, 2009 | 11:11 PM
initiald843's Avatar
gas gauge light out
my gas gauge light is out, only the needle illuminates. does anyone know how to pull the cluster out to change the bulb?
Old Sep 8, 2009 | 11:23 PM
FMB's Avatar
FMB
If I remember correctly, you need to pull the trim then there are 4 screws that hold the cluster in (and a couple of connectors in the back after you pull the cluster away a bit). Been awhile, so someone else chime in here. As for changing the bulbs, dim the cluster lights to off or almost off, then tear things apart and change the bulb, when it is all back together, turn on the headlights and slowly bring the cluster lights to full brightness again.
Old Sep 9, 2009 | 08:46 AM
puffsmokeonya's Avatar
ya thats about right. take off your kick panel. (the piece infont of your knees) then the piece around the radio. only one screw. (its near the glove compartment) then get the peice around the cluster. then a bunch of philips head screws hold the cluster in. change the bulb and your done. hope this helps buddy
Old Sep 9, 2009 | 08:48 AM
oh ya dont forget about the two screws in the bottom of the kick pannel. and the few things that plug in here and there (they are easy all color and size diff)
Old Sep 10, 2009 | 11:33 AM
sounds like way to much just to change a bulb! thanks for the replies guys.
Old Sep 10, 2009 | 01:01 PM
does anyone know what kind of bulb i need to replace it with?
cappykd
Jun 23, 2008 04:45 PM
paroxysym
May 27, 2008 07:12 AM
THURENfab.
Aug 8, 2007 07:02 AM
Scovo1
30
May 11, 2007 01:08 PM
04ctd
15
Apr 30, 2006 08:45 AM
