FYI on SB heavy duty Hydraulic assemebly
Old Jan 18, 2009 | 07:37 AM
RAMRODD's Avatar
Yesterday coming up to a stop light my clutch wouldn't disingauge. What happened is where the metal hydraulic hose that connects to the slave cylinder came off. The reason is there is a little roll pin either was never in all the way of slowly vibrated out. Not sure witch one.
Was a easy fix didn't loose the o-ring or the rollpin put back together and then had to bleed the system and worked fine.
Just wanted to let you guy know, something to check next time your under your truck.
I was abel to drive my truck to get it off the street. I shut it off and put it in first and it took off. I shifted all the way up to 6th gear with no clutch and it shifted real smooth even when downshifting.
Attached Thumbnails FYI on SB heavy duty Hydraulic assemebly-yhst-76613103363114_2037_2745035.gif
Polarlys
26
Jan 20, 2017 12:09 AM
ramfreak01
May 19, 2010 11:01 PM
dezl-andy
Nov 1, 2009 10:04 PM
FMB
Sep 5, 2005 01:44 PM
Mexstan
22
Jun 8, 2003 03:26 PM
