Fuel System Mods
Guest
Posts: n/a
Fuel System Mods
Can anyone tell us if there is a typical set of mods that should be done to the CTD. I used to own a PSD and there were a ton of improvements to be made with fuel system mods. If there are any for the CTD are there specific kits that are sold that help the performance or would I be better off putting together the equipment myself. Thanks
You will want to get a fuel pressure gauge so you can monitor your fuel pump's pressure as a starting point. If you start seeing the pressure dropping to zero you may want to think about adding a pusher pump or replacing the stock pump.
I kept my Aeromotive fuel pressure regulator from my old Ford's custom fuel system to use on my Dodge once its needed.
Originally posted by gdh11
Next stupid question - if I have a tri-pod where can I put a fuel pressure guage? Thanks
As for the fuel pressure thing, Diesel Dynamics has a kit for the 3rd gens to handle power up to 500+ hp. and the price isnt to bad either. Also the FASS, and Preperator pump set ups are nice as well with increced filtration.
No one sells them in a 4 gauge pillar mount option that I know of (is yours pillar or a dash mount?). What I ment was you can get the single "add on" pillar gauge mount and mount it to an allready existing 3 gauge pillar mount to have a four gauge pillar mount.
wrangler04
16
Aug 15, 2007 08:13 PM
Igor
Aug 7, 2007 12:37 AM
tristan21
Jun 19, 2007 04:57 AM
Steve C
Oct 16, 2006 11:32 PM
