fuel system ????
Old Oct 29, 2005 | 10:34 AM
doug60's Avatar
Cool fuel system ????
Well I finally finished my custom fuel system. Front half Scotty smart fuel, rear half custom. Half inch fuel pick up to a check valve/holley 60 micron high flow screen/ weldon 2005 fuel pump/0 to 15 pound 2040 weldon regulator. To the Scotty smart fuel system. Got it set at 10 pounds. The problem is the check holds pressure in the system to long and I think it is adversly affecting the starting. The stock lift pump wires fire up a relay to send power to the weldon pump. The stock system fires the pump for about 5 seconds to prime the system then kills power to the pump for startup. My check valve is holding pressure until it bleeds back through the regulator return line. the reason I added the check valve is , every time I worked on the pump there was never any fuel in the lines. So I figured making the pump start dry every time was a bad idea but now its a problem. Also have the fuel lines drain back to tank may keep the fuel from gelling. What do you guys think???? thanks , doug
Old Oct 30, 2005 | 07:35 PM
doug60's Avatar
For winter temps, do you think better to let the fuel drain back to tank. I don't know witch will be worse, empty lines, any condensation is sure to freeze.
RiverRat2
Oct 15, 2019 10:59 AM
ado2b1
Jul 6, 2007 09:35 PM
DISTURBED
Mar 11, 2007 09:14 AM
chucktownsend5
Mar 8, 2005 08:21 PM
