Fuel PSI
Old Jul 24, 2006 | 11:04 PM
juice's Avatar
Fuel PSI
What fuel pressure would be adaquate to operate my truck with the Juice on Level 5. I determined that my increase in EGT and decrease in mileage came from the addition of the Walbro kit. I am not complaining about the kit at all but I think that I may be providing too much fuel. My mileage went from 16-18mpg to around 12 mpg. I am considering putting a fuel pressure regulator in line tothe fuel filter but I don't want to starve my lift pump of fuel supply.
Old Jul 24, 2006 | 11:45 PM
blh1972's Avatar
What kind of pressure do you have now?
Old Jul 25, 2006 | 03:27 PM
juice's Avatar
Actually I have a fuel psi gauge on order. I can only imagine that my psi went up do to the increased EGT's and more black smoke with full throttle than before.
Old Jul 25, 2006 | 04:58 PM
Dodgezilla's Avatar
Your stock LP should be OK if you are just running one box. It will probably pull the pressure down to 0 psi though on a hard run. 8 or 9 psi is the standard on these 3rd gens. With an aftermarket pump like a FASS you will see around 18-20 psi....
Old Jul 25, 2006 | 05:03 PM
cquestad's Avatar
Don't push so hard on the skinny pedal!
You are not less efficent than before...you have more power because your OEM pump was starving your CP3.
That is not a fair comparison. You are not pushing more fuel through than you need...
I find this post the most humorous of the week.
Old Jul 25, 2006 | 11:49 PM
no_6_oh_no's Avatar
More likely it went down.
Rail pressure is falling like a rock and and the ECU is trying every way possible with event length and timing to make up for the lack of pressure. Too much of that and say bye bye to the CP3, possibly an injector or 2, maybe a piston.
Old Jul 26, 2006 | 10:22 AM
cquestad's Avatar
oh no...
He has higher EGT's cause he is making more power now...not starving the injection pump. Level 5 on the Juice will run a stock lift pump dry.
More power on tap...more fuel burnt.
Old Jul 26, 2006 | 04:55 PM
no_6_oh_no's Avatar
Woops! Missed the Walbro setup.
38 Cigarette
16
Aug 28, 2015 11:27 PM
schamran
Dec 14, 2009 08:20 PM
nrussell
Jul 23, 2008 08:58 PM
Tommy93w350
Aug 7, 2007 12:15 PM
Dave88LX
15
Sep 4, 2006 09:30 PM
