fuel lines, with dual feed kit
Old Sep 14, 2008 | 07:12 PM
pullin hard's Avatar
ok, i have a leak in one of my factory fuel lines, i have the dual line kit, and a stage 3 pump, the factory steel line that has the pressure relief valve in it is leaking, a small pin hole, probably from bending it out of the way when i installed the relief valve. anyway, i am wondering what you guys do with your fuel lines when running the bigger CP3 pumps, and or dual lines from the CP3? there must be a better way then to have this line with a relief valve on it just sitting there. i also noticed that some of my after market rubber lines are starting to crack. what do you guys do and can you point me in the right direction before i have to buy another stock fuel line that really does nothing. thanks
Old Sep 14, 2008 | 11:15 PM
jlibert's Avatar
you're lucky you caught it before it broke off completely. I removed the line all together, and ran a straight fitting directly from the fuel filter to the CP3. Here are pics of what you can do to fix your problem. Richard at Glacier diesel sent me these parts.
Old Sep 15, 2008 | 12:58 AM
are you running the dual line?
Old Sep 15, 2008 | 01:16 AM
jlibert's Avatar
I was when these pics were taken.
Old Sep 15, 2008 | 01:51 AM
thanks for the pics, i just need to order the parts i guess.
Old Dec 7, 2008 | 10:45 PM
chromestack's Avatar
What size are the fittings & what are they called? I had this happen to my truck, also.
modified03
May 26, 2008 04:49 AM
EQUIPPRO
Feb 14, 2007 09:04 PM
deezilpwr
Oct 22, 2006 12:45 AM
billmac
0
Mar 20, 2006 03:03 PM
