Fuel delivery problems
Old May 23, 2006 | 07:13 PM
juice's Avatar
Yesterday my truck began to act up. I felt like the tranny was slipping. I knew that my tranny needed to be rebuilt to accomodate the juice box but it hadn't really shown signs of wear. So on my way to work my truck began to surge which to me seemed like the tranny was slipping BAD. So I sent it to a local tranny shop to have them upgrad the tranny. According to them, it was not my tranny at all. Even though my "Check Engine" light didn't come on they say that there are 2 fuel delivery code errors. One for fuel lift pump circut low voltage and one for high pressure common rail error. What the hell? Has anybody ever ran across these errors and if so what was the solution. Thanks
Old May 23, 2006 | 10:42 PM
juice's Avatar
Nobody has any solution to these problems????
Old May 23, 2006 | 11:10 PM
T398's Avatar
What where the two codes it threw?
I have been having some trouble with my juice since I got it updated to the 2.1 version, surging and or more like its missing on one cylinder.
Old May 23, 2006 | 11:49 PM
staarma's Avatar
It's likely your lift pump. If you haven't upgraded it yet then you will need to. Was it missing at around 2700-2800 RPM? That's where mine started but it never threw a light at all. The first code is due to no pressure at the lift pump and the second is your rail pressure dropping because you drained it, no fuel. You can do a search on lift pumps here and you will find all of the info you need.
Old May 24, 2006 | 03:38 AM
Dodgezilla's Avatar
Time to upgrade...
Old May 24, 2006 | 11:59 AM
Spooler's Avatar
Lift pump code is P0169 for low voltage. My truck's LP is being replaced at this time. Skipped hard a like crazy at idle when it threw the code.
Old May 24, 2006 | 07:09 PM
bekim's Avatar
Do a lift pump before you lose the injection pump as well. People are buzzin about the Walbro Glacier unit. The Fass seems for the hardcore bomber IMHO.
GETA FUEL PRESSURE GAUGE!!
Mike
eyework
Feb 22, 2011 11:23 PM
HorseHauler05
Aug 27, 2008 06:55 PM
Burpl
Nov 24, 2004 09:14 PM
piesterdodge
Aug 16, 2003 04:59 AM
