Dyno testing different stacks
Old May 24, 2006 | 08:14 PM
Timinva's Avatar
DTR Advertiser
I spent a couple hours on the dyno tonight, testing different stacks on my 06. I have a TST PMCR with the 05/06 twins program in it as a baseline with a htt 62/12 it dynoed 460/840. With a MP8 stack version it went 479/885. Took the mp8 off and loaded a 2.2.7 Triple dog, on tow it went 475, on performance 494 and crazy larry 512hp. On the Crazy Larry the torq went up over 100ftlbs to 989. I had to turn the tst down alot to make the power but the power is incredible on the Crazy Larry & Tst Twins, Lots of smoke even at 40 lbs of boost. I did the BD/TST runs about my 15 or 16th runs and my intercooler was hot so I think it will show more power next time. All runs were uncorrected on #2 only. Without a doubt on my truck the Tst & Crazy Larry make the most power. Just figured I would put out what works for me. Tim
Old May 24, 2006 | 08:22 PM
W.F.O.'s Avatar
What did you set the TST at when you made the most power?
Old May 24, 2006 | 08:28 PM
Timinva's Avatar
DTR Advertiser
The most power was 4 over 1, Torq was highest on 2/2. Anything higher and egts would go crazy and the smoke would not clear. At Claremont next week I am gonna try 3/1 And see how that does. You can not use alot of the TST with the crazy larry and stock cp3. When my stage 2 is on I might be able to add more tst. Tim
Old May 24, 2006 | 08:41 PM
JDGPULLER's Avatar
I figured you would already be on here, I will try to get back to the dyno tomorrow night a little later { seth says the rate drops alot after hours, if you know what I mean }.
see you tomorrow, dont forget the ECM
Old May 24, 2006 | 08:43 PM
Dodgezilla's Avatar
Man! I wish I had a dyno available to me whenever I felt like experimenting...
Nice numbers! I'm just trying to get to 500hp. I guess we'll see how close I am at Claremont.....
Dave88LX
Dec 8, 2006 02:53 PM
andyr354
Aug 15, 2006 11:05 AM
